Turbo Cold Side Piping Question
Old Aug 18, 2010 | 05:57 PM
Fastbird93's Avatar
Ok, so my CRT elbow has a 3.5" outlet, and the rest of my piping is 3". Would I potentially see a pressure drop from the sudden change from 3.0 to 3.5" diameter along the way after the intercooler? I'm thinking right about the bend point coming out from under the car is where the switch is going to be made, with a 3.5" pipe running behind the radiator to the TB and 3" everywhere else, including out from the turbo.
Thoughts?
Old Aug 19, 2010 | 05:46 AM
MikeGyver's Avatar
Stepping up is usually just fine, especially if it's not right before the MAF.
You can easily make a smooth transision with a piece of 3.5" tubing that's a few inches long. Cut a triangle out of it down its length with a base of 1.5", close up the gap and weld it and you'll have 3" on one side.
Old Aug 19, 2010 | 08:04 AM
Fastbird93's Avatar
No maf so I'm not worried about that. I'm just going to do a transition hose at the elbow to get the car going (functionality) then once it's up and running, I'll order some of the 3.5" stuff and make it look better.
Old Aug 19, 2010 | 08:37 AM
razor02097's Avatar
Aren't you using Aluminum for your cold side? You could maybe use a stainless adapter just to go from the outlet to your cold side?
Old Aug 19, 2010 | 09:16 AM
Fastbird93's Avatar
Yeah, just using aluminum. Not worried about using a silicone transition hose at all, those things are plenty good.
DirtyDaveW
Dec 1, 2016 05:37 PM
MadMav
Feb 6, 2015 11:02 PM
birdblack
Exhaust System
Jan 4, 2015 09:41 PM
cmdeshon
Dec 27, 2014 10:06 AM
cmdeshon
Dec 12, 2014 10:51 PM
