Turbo pipeing for t67
I have a t67 .96a/r and the sts kit came with 2 pipe. well im nw upgrading the block and want to up the boost to 12-14 and want to run 3 pipe from infront of the axle to the intercooler and 3 out to intake. Is this pipe too large if the boost is 7-9 on the low side and 10-14 on the high? should i go 3 or smaller? whats the pros and cons Thanks
Re: Turbo pipeing for t67
I went from 2" dual in/out intercooler to dual 2" inlet and 3.5" single outlet and what ever turbo lag I had was gone. For you since your kit is in the back I would think you would not lose that much lag... 1/4 to 1/3 of a sec. from closed to wide open throttle. Don't forget that the charge pipe from turbo to intake manifold stays charged with boost.
brothaslide
Jan 9, 2016 12:11 PM
detroitmuscle
Jul 31, 2015 04:21 AM
Devinfoote87
Jul 30, 2015 09:54 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
