Vortech SC belt sizing
Old Aug 4, 2010 | 11:33 PM
onefastmx5's Avatar
Where do you guys get your belts? I'm running a 6" crank, 2.75" on the SC. Currently have a belt from NAPA (41" HD green truck belt IIRC) and I think its slipping. The auto-tensioner looks maxed out and I can push/pull the belt about 3/4". Can't find any charts, and i'm thinking about putting on my 2.5" pulley soon. I want a good belt that will last. How many miles do they typically go before needing replacement? Any help appreciated, thanks!
Old Aug 8, 2010 | 06:35 PM
Rhett's Avatar
You can go to gates.com and look up there catalog in pdf (sites down right now though), try looking at actual page# 659 (shows up as pg 757/789 on my droid). I just went thru this today on my car. I had originally ordered the 080400HD from Napa but it was too short when I tried to put it on this morning. I just ordered a Gates K080408 from amazon, my old belt measured 41.38" long. Unfortunately I couldn't find this in HD.
All of the belts on gates site are listed as Outside Circumference:
8 rib belts are 1-3/32"w (28mm)
080400 = 40.75OC (1034mm)
080408 = 41.38OC (1051mm)
Pretty sure I have the stock pulleys on my car as I only make 6#. You should be able to take your belt off, mark a line on it, and roll it on top of a tape measure or use a piece of string around it to check the length. Then just take that measurement and figure out what you need.
Might as well throw a new tensioner on there too:
Ford# F4TZ-6B209-A FORD 1994 F250 F350 E350 7.3L BELT TENSIONER ASSY
I bought mine off ebay awhile ago for $25 new
Hope this helps
Old Aug 11, 2010 | 10:15 PM
onefastmx5's Avatar
I bought the same tensioner on ebay
I bought Gatorback Poly-v #4080415 and #4080407 from amazon.com. Got both shipped to my door for $24!! The napa belt on the car now was freakin $40. Going to install this weekend and see what happens, which belt works with 2.75 pulley. Then put on the 2.5" pulley and see if i have a belt that works.
bunker
Jan 30, 2016 08:09 PM
RX Speed Works
Aug 20, 2015 03:40 PM
john henry
Aug 14, 2015 08:33 AM
colts0455
13
Aug 7, 2015 09:15 PM
