Mahle -31cc 2618 proper quench shape?
Old Oct 28, 2010 | 11:05 AM
bunker's Avatar
Would love for you guys to chime in.
I'm wondering if the Mahle -31cc piston which is a 2618 Alloy according to Mahle (called them) and their online chart, I just wanted to know if anyone bought them and has a picture of this piston, see if it is a proper inverted dome with proper quench, here is the part number:
SBC425030I31
Thanks guys, planning on running about 17psi.
Old Oct 29, 2010 | 01:11 AM
MikeGyver's Avatar
You didn't ask Mahle when you called them? I would guess they're full round as opposed to D shaped.
What do you mean by proper quench? D shaped to match the head chamber?
Old Oct 29, 2010 | 02:14 AM
bunker's Avatar
Yes I called they said they are D shaped which is great, I'll go for them on my next setup, wen with JE's this time, I just couldn't find enough info of others using them, but I also haven't found any negatives, in the end was my buddie's decision, but I must say the customer service from Mahle is extremely good, I couldn't believe it, their tech guy is awesome and two days in a row answered within 1 minute.
Old Oct 29, 2010 | 08:55 AM
mzgp5x's Avatar
I run -28cc JE forged 2618 blower pistons (4.030) in a 383 LT1. D shape. I have read that it is important to have a full circular raised feature to squish the fuel/ air mixture to the ignitor plug as the piston travels up on the compression stroke.
My forged assembly (Callies/ Eagle H-beam 6") has been working great for 7+ years with about 14 psi of boost. Runnung a 9.5:1 static compression. -31cc piston should be a good choice. Fluid flow is the most important criteria on a FI engine.
Also, blow-by was a concern/ problem of mine as I experimented. I ended up with an external vac pump (gzms 103). This solved all of my problems, and, a great power adder.
B.
Old Nov 1, 2010 | 02:16 PM
blown94's Avatar
Re: Mahle -31cc 2618 proper quench shape?
I bought them for my build but they dropped right to the builder, so im unsure of what they look like yet, but anything made by mahle is going to be top quality, and yes they are indeed 2618 alloy as well as the -26 and -28 stuff. I plan on about 15 psi myself from a D1SC for the 383 build.
Old Nov 26, 2010 | 09:56 AM
Kevin Blown 95 TA's Avatar
You'll be fine with those, I'm running the Mahle -26cc Powerpack pistons, which aren't as tough as what you're getting, and my engine makes 15# peak boost without any issues.
Old Dec 9, 2010 | 09:34 AM
jsetzer's Avatar
Been traveling way too much lately, sorry I missed this for so long.
Several pics of mine:
https://www.camaroz28.com/forums/sho...d.php?t=738817
Old Dec 30, 2010 | 08:10 AM
engineermike's Avatar
I've run both the SRP D-shaped dish and a Ross O-shaped dish. At first, I thought I liked the D-shaped dish better for better quench characteristics.
Later (after breaking more SRP pistons than I care to remember), I went with Ross because they could offer an oddball bore size. When I received them, I was surprised to find a O-shaped dish. After taking a closer look, I noticed a big advantage of the O-shaped dish. Since the dish is spread out over a larger area, it doesn't have to be as deep or close to the ring groove. This leaves a LOT more material in this area, thus preventing the lip from breaking off. I never broke a Ross O-shaped dish piston. On top of that, I've heard several experts comment that quench isn't nearly as important on forced induction.
Mike
jbert55
Oct 31, 2015 03:52 PM
jbert55
Aug 3, 2015 05:49 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
bunker
Aug 1, 2015 10:10 PM
Catmaigne
Jul 14, 2015 05:17 PM
