MAF conversion?
MAF conversion?
i have a 93 bird that im looking into turbocharging. that being said the 93 is a speed density car. i had thumbed through some posts about guys running boost on their maf cars in speed density mode with a stock ecm.... a few questions i have are what would be involved in converting my sd over to a maf system? what parts would be needed? or...would it be possible to run boost on my speed density system with some changes? what would be involved? i know the obvious answer is to go stand alone but i dont want to buy an entire system if i dont have to. im looking to put 5-600 to the tire on 2 bar.
Re: MAF conversion?
At first, i was dead set on ditching the maf because of the possibility of maxing out the maf and most SD tunes usually make a little more HP. I was dead set on converting to speed density, bought a 2bar map and spent hours playing with different tunes and setups. I couldn't get the car running halfway decent, so i went back to maf. I've discovered modifying the tune is really simple with the maf, and drivability is not sacrificed whatsoever. I would say try seeing if you can get the car dialed in with the SD first, and if that fails, convert over to maf for easy tuning.
tommalcolm
Sep 11, 2015 03:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
