Fuel regulator change..what do i change in the tune?
The old fuel system was a dual intank ractronix kit running stock lines, stock regulator and a hobb switch to engage the 2nd pump at 5psi.
The new fuel system consists of dual walbros runing at the same time into a aeromotive 13101 regulator which is boost referenced 1:1 and set @ 43psi.
Both system are using versafuller with 96lb injectors.
What will i need to change in the tune to compensate for the constant fuel pressure?
Thanks!
Thanks!
Re: Fuel regulator change..what do i change in the tune?
Why did you swap in the exact same system? and why is the 2nd pump running all the time? 95% of the time it'll be unnecissary and just wear out faster, be noiser, and put more heat in the fuel tank. Also it's not a good idea to massivley oversize the pump because at idle and cruise all that flow might overwhelm the regulator and return line. Progressively adding flow as it's required is the way to go.
Nothing. The factory fuel system uses a 1:1 front mounted regulator with return line and maintains a constant 43.5psi across the fuel inectors.
I also should have added that the stock lines were replaced as well with -8an feed/ -6an eturn.
here is the pic of the current system
Both regulators operate the same way.
1. Vacuum decreases fuel pressure
2. Boost increases fuel pressure
For instance when my car (stock regulator) was pulling 16" vacuum at idle it was at 37psi
When it was pushing 10 pounds of boost it was running at 53psi
I agree that your tune will require very little change as long as the fuel pressure is kept at the stock psi.
If at some later time you decide to increase the fuel pressure you will have to completely retune the car. It will affect almost all fuel tables as well as starting.
Crap for some reason I didnt think the vacume played any part on the new regulator. Thought it was only sensitive to boost. Feel pretty silly now lol
Sent from my DROIDX using Tapatalk
The regulator simply maintains 43.5psi across the fuel injectors (from the fuel pressure to the manifold pressure). If you have 10psi of boost in the manifold you need 10 more psi of fuel to maintain 43.5.
Same goes with vacuum. 1"hg of vac = 2psi. So if you have 10"vac in the manifold you only need 38.5psi of fuel pressure. Since this Delta pressure is always constant the PCM just needs a pressure constant and it always know how much fuel is entering the motor.
The formula is sqrt of (new pressure/old pressure) x old flow rate = new injector constant flow rate
for example if you change your fuel system from 43.5psi to 58 psi, you'll enter an injector constant of 110.75 #/hr instead of 96.
The reason I ask is I put in a Lonnie's double pumper and have, with a stock FP regulator, my fuel pressure at idle with vacuum tube is at 44psi like the OP. It was 38psi before and ran like a champ.
I have tuned it 6 ways to Sunday and it is great everywhere except at idle and light, light cruise. It fouls plugs within minutes with an AFR in the high 11s.
If the OP has an adjustable regulator the key might be to lower to the factory 37-38 psi.
You can however set your fuel pressure at anything you want if the injector constant in the tuning is rescaled appropriately using the formula in my last post.
So here is the question then: if fuel pressure is set above the stock 37-38psi will run rich even with a retue???
Two pumps should only cause a problem if you're running them both at the same time at idle (ie. the FPR can't bleed enough fuel back to the tank fast enough to control the pressure). If you're seeing 44 psi with the vacuum line attached then you're probably running around 50 psi with no vacuum. You may try increasing your injector constant by ~15% to compensate if you can't get the fuel pressure corrected.
I thought is was a leaky injector/s and was going to check that when the snow melts but now you have me thinking the install was done wrong and both pumps are on all the time.
Marcin, you're back in the game? Thought you parted out your old car dude? Well glad to see ya back? You still blown or did you go turbo this time? Sorry for the hijack but I concur what others have said. LOL
(50 / 43.5) = 1.15
(1.15)^0.5 = 1.072
Flow varies with the square root of the pressure ratio.
