Any F.I. guys using the Impala SS stainless shim head gasket?
Old Nov 14, 2011 | 06:05 PM
DirtyDaveW's Avatar
I know most of us are going in the opposite direction, trying to get a thicker gasket but my setup was spec'd for 8.8 static compression with stock 54cc heads. I now have Canfield heads that I'm pretty sure are 64cc so with all else being equal that puts me at 8.1 static compression. I've just bought some TFS 23 degree heads (thanks Realquick!) and they are inroute to Lloyd Elliot for the full 2.08/1.60 ported heads/intake treatment. They too are more generous in their chambers than the stockers 54cc so in addition to some milling, Lloyd recommended a Cometic .036 (compressed) gasket to get me closer to the orginal spec. I've used the SS Impala shim head gasket on 3 motors (nitrous and N/A) and they held fine. Just wondering if you guys had any experience (or theories) about using such a thin (.029 compressed height) gasket on a turbo or supercharger app.
Thanks,
Dave
PS: I'll either be sending the Canfields to Lloyd for porting or selling them as is.
Old Nov 14, 2011 | 09:43 PM
Kevin Blown 95 TA's Avatar
Re: Any F.I. guys using the Impala SS stainless shim head gasket?
I don't see why it would matter, the Cometics just have a thin inner and outer sheet and a middle piece that sets the thickness. I used the Cometics, though, and I went through the pain in the *** procedure of retorquing them after initial startup and cool down. I'm not sure of the suitability of the Impala gasket since it was an iron head engine, but your experience with using them on nitrous says something. My best advice is to just be careful with prep and torquing as I'm sure you are when you build an engine.
Old Nov 15, 2011 | 11:46 AM
RealQuick's Avatar
I would just use the .039 felpros (1079's?) and have Lloyd mill the TFS heads to the correct CC.
Old Nov 15, 2011 | 12:01 PM
DirtyDaveW's Avatar
Lloyd indicated he could only mill them to 58cc and to then use the cometics to get back to around 54cc or at least closer.
Old Nov 15, 2011 | 10:45 PM
Robsquikz28's Avatar
I would just use the felpros
Old Feb 21, 2012 | 07:45 AM
RealQuick's Avatar
Bringing this back up... Dave I am in the same bought. I have 65cc AFR's that Lloyd said he could probably only get down to 58-60cc. I would like thinner gaskets then the Felpro .039's. I have been thinking about the impala ones as well.
Anyone think using them with boost can lead to trouble?
Old Feb 21, 2012 | 05:16 PM
DirtyDaveW's Avatar
You may have to be a pioneer Jon
Lloyd ultimately only got my TFS down to 61 cc. I'm using the Felpro 1074's per Lloyds recommendation. I asked him specifically about the Impalas vs Cometics vs FP 1074 and, given that I won't have pristine block surface(just replacing the heads w/motor in the car) he only recommended the FP1074.
Update on mine, I finally found a local machinist to fabricate a bushing so I could use the CompCam composite distributor/oil pump drive gear. That's an expensive upgrade.
1. New Drive gear/shaft = $46 plus shipping
2. CompCams composite gear = $9x.xx
3. Machinists work to machine bushing and install it = $118.
Oh well, this should keep me from having to replace the bronze gear every year.
The weather is looking better and better. I hope to do the heads/intake swap in the next few weeks
Jon, how's your project car coming along? Have an ETA?
Old Feb 22, 2012 | 07:58 AM
RealQuick's Avatar
You'll be up and running before me. Moving into a new house in April, so my time to work on the car will be limited. I still need to have Lloyd port my LT4 intake and mill my AFR heads.
Things I need to do still:
Test fit new hotside
Fab cold side
Install top end
Install Classic FAST with Plug N PLay harness
Install dual walbros, 80# injectors, and Aeromotoive fuel pressure regulator
Connect catback to downpipe
Wire in WB gauge
too much to list really.
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
thenewkid
Nov 27, 2014 09:41 AM
