Max WOT timing ?
Old Nov 6, 2010 | 05:05 PM
onefastmx5's Avatar
Max WOT timing ?
Been conservative on the car while it was a daily. Headed to the track next weekend and wondering how much advance timing I can run on pump gas. Currently have the table set to 22deg to redline. Now that i have my dual wideband working i want to get a little more aggressive. Car see's about 7-9psi. I built a table starting at 30 @ 2000rpm and decreases linearly to 22 by redline.
Old Nov 7, 2010 | 06:30 PM
MikeGyver's Avatar
Re: Max WOT timing ?
Do you see any boost at 2krpm? I'd start by leaving the timing alone in the non-boost rpms, then go linear. You may have to dip timing down a bit at the peak tq rpm (somewhere around 5000rpm or so). Watch your fuel pressure at the top end of a pull. I just discovered my walbro was completely maxing out around 8psi.
Old Nov 7, 2010 | 11:31 PM
onefastmx5's Avatar
I don't see boost until around 3k rpm. Fuel pressure holds steady 45psi to redline. Just loaded a map today and it seems like it should pull harder. Would 25deg be too greedy? I know the PCM usually adds in 3deg, so that would be around 28deg at 7psi.
Old Nov 10, 2010 | 12:53 AM
rskrause's Avatar
Moderator
Without knowing about your combo, especially what your CR is it's hard to say much about timing, but if it's a stock short block, be VEWY VEWY careful with timing. In fact, 22 degrees sounds about right if it's a stocker. It will NOT tolerate detonation.
Rich
Old Nov 10, 2010 | 07:35 AM
onefastmx5's Avatar
yea stock 120k motor, only mod is the 1.6 rockers.
Old Nov 10, 2010 | 09:28 AM
rskrause's Avatar
Moderator
Don't advance the timing beyond 24 degrees.
Rich
Old Nov 10, 2010 | 11:38 AM
onefastmx5's Avatar
Rich
That helps, thanks
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jayblev95
Jan 20, 2015 01:30 PM
ChameleonGreen
Sep 2, 2002 05:15 AM
