Wideband install ?
Old Aug 24, 2010 | 11:28 AM
a4z28's Avatar
Wideband install ?
I am in the process of getting my s trim hooked up and want to be as safe as possible. So i am looking at getting a wide band to keep a eye on everything, is it hard to install and where is the best place to install it at? I have pacesetter long tubes and there 3 inch ory pipe. I was thinking about where the y pipe merges but am not sure. Also where should my air fuel be at off boost and on boost 7 psi max. Thanks Here is a link to the one i am thinking of getting what is your thoughts?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Aug 24, 2010 | 07:05 PM
DirtyDaveW's Avatar
As long as it's not too close to the turbo outlet I think it doesn't matter that much. Mine is in the downpipe about a foot and a half back from the turbo.
Old Aug 24, 2010 | 07:44 PM
MikeGyver's Avatar
I have thay same AEM gauge and it's been great. I can't imagine trying to tune a turbo car w/o one.
Apparently a turbo's backpressure can affect the accuracy, so mount it after the turbo (or after Y pipe collector if supercharged) at an angle of about 15° above horizontal so it can drain condensation. I would stay at least a foot away from the end of the tailpipe so the reading isn't skewed by atmosphere.
AFR in closed loop should between about 14.7-15.2.
power enrichment mode on 7psi should be about 11.8-12.2
Old Aug 24, 2010 | 10:24 PM
QWKzee93's Avatar
dont mean to highjack the thread but how about placement in true duals?
Old Aug 24, 2010 | 11:26 PM
MikeGyver's Avatar
One side or the other is about all you could do. Might be able to place it in an H pipe if it's not too long.
Old Aug 26, 2010 | 09:36 PM
onefastmx5's Avatar
I had it installed on my right side only, when 1 day the LED started acting up. Called autometer and they said to send in for repair. The other day a BRAND NEW wideband/harness/sensor showed up at my doorstep Now, I'm in the process of doing dual widebands. I have pacesetter LTs and i installed the bungs on the opposite side of the O2s, on the collector. I like the fact that i get a reading on both sides, now i just need to find another 4378 gauge.
Old Aug 26, 2010 | 11:54 PM
MikeGyver's Avatar
One could run 2 sensors and elecrtonically average the 2 readings to allow for one gauge.
Old Aug 27, 2010 | 08:59 AM
Procharged94Lt1's Avatar
I kinda like the dual idea as well- lets you know if one bank is leaner than the other- could be a nice warning if something is off before things start to break.
Be nice if someone offered a dual reading single gauge. It can't be that hard to do...
Old Aug 27, 2010 | 11:12 PM
onefastmx5's Avatar
Exactly why i'm doing it, always better safe than sorry. 1 gauge for both would be cool but i haven't seen that. I'm doing both meters in a triple pod, with the other being boost.
Old Aug 28, 2010 | 05:40 AM
MikeGyver's Avatar
I'm thinkin 3 position toggle switch... right, left, or average both sensors.
Old Aug 28, 2010 | 08:11 PM
onefastmx5's Avatar
"If you build it, they will come"
Old Aug 29, 2010 | 02:32 AM
If I were rich I would buy a pair of gauges and rip then apart and try to make one myself...
Old Sep 10, 2010 | 12:07 PM
mzgp5x's Avatar
App... 97ss 383_D1/ MM6
I did a DynoJet WB AFR. Mounted the analog gage on the "A" pillar.
Also had a Autometer AFR Gage next to it with a 3 position toggle.
It reads Rt/ Left Bosch O2 sensor(s). Toggle is convienient access by the steering column as I drive on down the road. AutoMeter AFR gage is easy to read w/ the WB analog gage located below. Really helped me with the PCM tune. The DynoJet also can data log internal and to a Laptop via USB.
B.
Old Sep 11, 2010 | 07:22 AM
Kevin Blown 95 TA's Avatar
Maybe get a switch with gold contact or something to keep the voltage drop to a minimum.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
