LT1 Boost PT88 Build
Old Oct 16, 2011 | 06:16 PM
RealQuick's Avatar
Another new build for a customer.
Forged 355
LT1 heads from ET Performance
custom BRE cam
LT1 boost Custom PT88 Kit
1 3/4" headers
2.5" crossover
3.5 downpipe
50mm JGS wastegate
60mm JGS BOV
4" A2A IC
3" IC piping
Started building the pass side header today.
Old Oct 16, 2011 | 07:07 PM
MTL_Z28's Avatar
Re: LT1 Boost PT88 Build
Let's do this!!
Old Oct 16, 2011 | 07:25 PM
MTL_Z28's Avatar
Jon, just a couple more details...
I noticed that on your website when you build the hot side pipes that you sometimes go under the front sway bar, but mine is removed and probably won't be going on anytime soon, just in case that makes it easier for you.
Also I will be deleting the ABS with the SJM mfg delete kit too. Not sure if that gives you even more room maybe.
Old Oct 17, 2011 | 08:30 AM
RealQuick's Avatar
Both are details I need to know... and make things easier for sure!
Old Oct 18, 2011 | 10:36 AM
RealQuick's Avatar
Old Oct 18, 2011 | 11:11 AM
Purple Poncho's Avatar
Great plug access.
Old Oct 18, 2011 | 11:43 AM
RealQuick's Avatar
Thanks! Yeah, the benefit of building lots of kits is that you continously learn and make the kits better as you go.
Old Oct 18, 2011 | 08:17 PM
MTL_Z28's Avatar
Originally Posted by Purple Poncho
Great plug access.
That's what I said
Hey Mat are you going to Dexter's this sunday??
Old Oct 18, 2011 | 08:34 PM
RealQuick's Avatar
Old Oct 18, 2011 | 10:54 PM
Is it this weekend? Yeah, hope to.
Old Oct 19, 2011 | 06:48 PM
RealQuick's Avatar
Old Oct 20, 2011 | 12:23 AM
Procharged94Lt1's Avatar
Looking good- can def see the improvement of your kits over the years.
-I think its about time you get some tabs made to weld on the headers to promote your business a little...def work you should be proud of.
Old Oct 20, 2011 | 07:09 AM
RealQuick's Avatar
Thanks man. I have thought about that before and looked around online, but couldn't find a place to make them. Do you have any ideas on this?
Old Oct 20, 2011 | 08:15 PM
RealQuick's Avatar
Old Oct 21, 2011 | 05:31 AM
I googled "custom metal label" and "custom CNC labels" and got a few hits from companies that looked decent. The problem is all of them obviously need to know what you want to give a quote on price- but I have known most places to be pretty pricey per piece unless you are ordering a large quantity.
Simplest way I can think would be to just buy a set of metal punches and then just type out with each letter what you wanted it to say. Just use a small 1"x3ish" tab of metal, say 16 or 18 gauge welded onto the top primary tube. Simple as saying for instance on this kit...
_________________
| www.lt1boost.net |
| PT88 Cust #XXX |
edit..^^ the lines won't line up but you get the idea..
Easy way to track the kits down the road too- esp when they get bought/sold/modified etc. At least you'll know what it started as.
