PDA
View Full Version : Computer Diagnostics and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Vats System..i think
  2. Datamaster log file
  3. Reprogram for cam
  4. Datamaster Help translate
  5. BigStuff Gen3
  6. Help-quick!
  7. Redhat scantool?
  8. Would this laptop work well with tunercat/LT1edit?
  9. Brake light is stuck on??
  10. those with 32# inj. need tuning info please
  11. need help check engine light is on code p0400
  12. Sample BIN
  13. 94 LT1 issues
  14. ECM going bad
  15. Need help with getting my pcm programmed
  16. new power lock actuator or new BCM?
  17. New transmission...What needs tuned?
  18. leaning out at high rpm
  19. Engine knock?
  20. Tuning Mailing list
  21. Help with check engine codes
  22. wanting to get Madz28 email tuning, which akm cable?
  23. OBD scanner 1 or 2 ?
  24. Where is this extra timing coming from???
  25. Best/easiest way to tune my car?
  26. could the OBDII response, be faked?
  27. USB-Serial Converter or PCMCIA in DOS Mode
  28. BS3 manual
  29. Did I damage my ECU?
  30. Need Corvette M6 File
  31. Fuel tables in TunerCats
  32. Failed emmissions. Need tuning advice.
  33. Need a "flagging" tool/option
  34. Autotap or tunercat
  35. USB-Serial Converter w/ datamaster
  36. New Parts, want to buy a tuner prog, suggestions
  37. Need a programmed Lt1 or bin for 373 gears A4
  38. 383 datamaster run falls on its face
  39. Security System
  40. Anyone have any 99-01 LS1 tunes or 5.3, 6.0??
  41. new motor programming needed
  42. Tunercat:car feels weird after I reprogrammed for gears
  43. Is my motor running rich or lean??
  44. help LT1 edit 6 speed program needed
  45. Tuncercat
  46. What is needed to use HPP cable?
  47. Looking for a tuner in southeast florida
  48. new to DataMaster question
  49. Transmission Needs Programming
  50. Aftermarket EMS
  51. WOT timing on a blown stock LT1
  52. LT1 Edit
  53. Help posting/reading freescan log (FRED or another guru)
  54. using 95 obd2 style connector on obd2 car
  55. PCM questions for LTCC
  56. Syclone programming?
  57. hppIII On My Auto Ls1 . Yep Iam retarded .
  58. Lt1 tunning in Oklahoma
  59. home made cable problems?
  60. "incorrect message sent"...
  61. FAST & delteq
  62. Deleting EGR in LT1 Edit
  63. tune problem
  64. Reprogram LT1 Computer
  65. 88 iroc gauge problem
  66. Heeeelp... Gauges no signal
  67. OBD-II connector pin-out; and SES light pcm pin.
  68. Need Someone to tune pcm
  69. tune help needed
  70. WOTelectronics trouble/ contact info?
  71. flashing a computer
  72. Tuning Computer in DOS (TTS Datamaster)
  73. what knock sensor to use
  74. Fitting vortec pcm into lt1 opti elimination
  75. Finally, a LT1/LS1 Dyno Tuner in Northern California
  76. Attention: madz28 and all others welcome
  77. Code 11 any help confused
  78. Help, which Hypertech to buy?
  79. obd2 lt1edit
  80. Is it possible..? advanced PCM hackers inside
  81. Can I delete this?
  82. Enabling Traction Control on non trac control cars
  83. More LTCC question
  84. sp2 and datamaster users
  85. taking out fuel
  86. 93 z28 383, is it worth the money too...
  87. can i see datamaster log in excel?
  88. obd 1 to obd2 conversion
  89. Thrown codes: P0135 & P0137; after LT install
  90. CKP - Reading a Negative 15???
  91. computer help
  92. BLM Locker Issues on a 93 SD car
  93. Bad LT4 knock module?
  94. 2bar+ support for DA cars.
  95. Aftermarket TB Drill Mod, Who's done it???
  96. News Flash!! TUNERCAT OBD2 TUNER AVAILABLE NOW!!
  97. Dyno Tuner in Toronto area!
  98. TPI computer programmer
  99. CODES 34 & 44 PLEASE HELP
  100. Stock OBDII M6 tune needed for conversion
  101. Is there a crash course I can take to learn Tunercat?
  102. autotap: 1 question
  103. Looking for a 306/stock heads tune!
  104. neeed a program
  105. 94 vs 95 cpu
  106. biggest injectors on stock pcm
  107. ODB1 - Code 26 Help!
  108. Can I add a switch to turn Traction Control on/off?
  109. changing to obd1
  110. ABS inop
  111. Taking out battery mess up computer??
  112. Idle PE mode guys inside
  113. Communication Error
  114. Just starting out with tunercar have a few ?'s
  115. CKP Sensor unplugged - Ok to pass emissions?
  116. HPtuners/EFI live all info needed
  117. Tuning for cc306 & 385 LT1
  118. ABS INOP...getting annoyed now...
  119. tunning question
  120. Help identifying wiring harness
  121. Please Help!! Wiped out PCM!!!
  122. 383/Turbo tuning
  123. Programming install question.
  124. Tuning quesions
  125. Turning off knock sensor....
  126. Code 36 and 42 problems
  127. How do I fix rich open loop idle?
  128. Tach Signal???
  129. auto comp in manual car
  130. Idle issue
  131. Just got my hands on laptop... where do i start?
  132. In Car Computer
  133. High Stall Problem
  134. Does locking integrators at 128 = open loop?
  135. Bosch 30#?
  136. Using Laptop To See Engine Info
  137. Please Help Code 13 02 Open Circuit
  138. HPP questions
  139. Need dos upload program
  140. If Serial port doesnt work...try PCMCIA???
  141. A4 trans limp mode
  142. Possible Bad PCM
  143. why is my AFR constantly going to 9.6 on WOT?
  144. can i upload a tune from another car to mine?
  145. Do you need integrators for block learns?
  146. xe230 236 base tune needed
  147. Datamaster won't work but freescan does
  148. stall wall
  149. FAST and OBDII users inside
  150. Extended Crank Period
  151. I have a million and one questions, Hp tuners...
  152. Coding 95 Z28(OBDI with J1962 (OBDII) connector
  153. Problem with OBDI port not communicating, V6-V8 swap
  154. Scanner for 93 LT1 cars.
  155. A little help with Tuner Cat?
  156. Readings on scanning tool question?
  157. PCMCIA card problem with LT1 Edit
  158. Examined a Hypertech chip from a 93Z, results within.
  159. anyone use dynotex in san antonio
  160. Anybody know how to reset Hypertech PPIII
  161. Computer tuning for LS1
  162. Need some help converting .lt1 file to .bin file?
  163. need info
  164. What laptop???
  165. TunerCat question?
  166. 4L60E in Limp mode?
  167. pcmforless tune
  168. Tunercat Help
  169. Tunercat for ODB2 - Wassup?
  170. engine off...knock counter still going
  171. Another Thumbs Up for MadZ28.com Tuning
  172. Getting a ODBI PCM to work on a OBDII car?
  173. LT1 Edit Comm Error
  174. Where to get software?
  175. Computer not communicating with trans??
  176. Scanmaster Spark Timing Results & Question...
  177. LS1 Edit
  178. Can you fry a PCM will reading it?
  179. Code 36
  180. Jet Stage 2 PCM, Worth Buying??
  181. LTs w/out the use of STs
  182. 383 datamaster file 12.4 pass something wrong????
  183. OBD II editing software
  184. Need LT1edit file for xe 224/230 cam.
  185. '95 OBD II Connector to OBD I conversion
  186. EFILive
  187. datamaster....what is CCP DC
  188. HELP! O2s all over the place
  189. Non-SES stored codes on OBD1 cars?
  190. How to change Max MAF fail point
  191. Question about waste spark ignition
  192. Wot electronics OBD I cable?
  193. Who can program a chip for a 93 LT1 Firebird?
  194. Service Engine Soon light - garage can't access database
  195. Did I have my first tuning "oh sh#$"
  196. LT1, not reading key, no communication with computer
  197. hp tuners anyone familiar with this?
  198. Will Tuning for Nitrous effect N/A dyno numbers?
  199. help with timming ????
  200. PE seems to be affecting open loop idle....
  201. Anyone have an FAQ for programming?
  202. Anylize my WOT run log.
  203. I need help with my lap top to PCM conection
  204. WOuld anyone mind checking out my scan logs?
  205. No juice..but batteries good??
  206. Different ways to get IAC count
  207. Modifying ASR on the LT1
  208. Turning off Traction Control
  209. Data logging for a '96 OBDII
  210. Looking for 8# blower tune w/42# inj.
  211. Is there a detailed website explaining how to use LT1 Edit?
  212. Can post o2 exhaust leaks cause faulty o2 readings
  213. Will aftermarket tune fail emissions?
  214. Left and Right pulse widths are different, yet BLM's and INT's are locked to 128??
  215. predator tuning
  216. EXPERTS in here, I have a SERIOUSLY strange Air/Fuel Ratio issue. Need ideas !
  217. I'm wanting to get
  218. need LS1 edit help asap...gotta set my injector tables back closer to stock!
  219. new gears, after tune, still hitting limiter on 1 -2 shift
  220. Cannot connect to PCM with lt1edit...Fuel pump not priming.
  221. wont shift at wot. lt1 edit guys in please
  222. Changing injector size
  223. p1870 code?
  224. ? about A/f ratios and power
  225. Cant seem to get open loop idle to work.
  226. 94 LT1 PCM Diagram - HELP
  227. how do you lock the blms to cell 15
  228. Can anyone look at my datamaster file...
  229. The dreaded Knock after Shifting....
  230. MAF Tables for Cold Air
  231. mad z tuning for almost stock car?
  232. Can I just get any old shiftlight or tach for my '95 LT1?
  233. Have a ? about Fast and my new Throttle Body
  234. Scan Software and cables?
  235. Scan Software?
  236. MAF Readings Peaked
  237. SES code 1642
  238. High BLMs, low fuel mileage, what gives?
  239. How much good does the Power Programmer do?
  240. Module Test
  241. ? on Tuning for Accel Injectors
  242. Fuel guage problem
  243. Changing tunercat table listings
  244. Removing pcm batt power?
  245. VSS Myth Fact or Fiction?
  246. So what can I expect from a dyno tune?
  247. Few supercharger tuning questions please...
  248. Stock 1993 Bin for manual (m6)
  249. What do I need for TunerCat programming?
  250. 2.8L computers? Same as TPI???
