Need dos upload program
Old Nov 21, 2004 | 03:49 PM
Taylor's Avatar
I can't find one to download I was wondering if someone could email me a dos upload/read program.
taylorb@mtnhome.com
Taylor
Old Nov 25, 2004 | 01:38 PM
MyTMous's Avatar
Re: Need dos upload program
may I ask why a DOS program?
and not a windows program.
Old Nov 25, 2004 | 01:51 PM
Taylor's Avatar
Well I can't get the windows one from tunercat to work with my car. That is why I was hoping I could get a dos one that might work so I don't have to drag the desktop out in the garage to program the car.
Taylor
Old Nov 26, 2004 | 07:27 AM
MyTMous's Avatar
what is tuner cats doing that it doesn't work with yours?
Are you getting an error, I've used and loaded and taught tunercats to a few people, this is why I ask, I've use an old dos based and it sucked, lots of issues.
let me know what your OS is (win98,XP or whatever) and what you are using as the cpu(speed, memory).
also what kind of cable you have(homebuilt, AK, other)
Also where are you located?
Old Nov 26, 2004 | 10:21 AM
Taylor's Avatar
It doesn't find the PCM. It is the laptop I think. I can get free scan to work, but datamaster won't work can't find the PCM either. I used this laptop on my 93 and datamaster work fine. The laptop has win98, 100mhz, 40mb ram. The cable is one that is sold on ebay.
Taylor
Old Nov 26, 2004 | 01:00 PM
MyTMous's Avatar
I had a problem like that, it was in the com port setup.
once I relected the right one, it worked.
Also here, it's the tunercats, dos based flash prog.
you must run from DOS, and not a dos window in widows.
read the pdf.
http://www.buildaracecar.com/flashprog.zip
Good luck,
Old Nov 26, 2004 | 02:19 PM
Taylor's Avatar
Thank you for the file. I have adjusted every thing on the com port setting, the laptop works fine with the 93 I had, just doesn't like the 94.
Taylor
ss owner
Parts Wanted
Apr 8, 2015 03:36 PM
mikey4play
Mar 15, 2015 11:45 AM
Injuneer
Dec 15, 2014 09:36 AM
