Turning off knock sensor....
Old Nov 26, 2004 | 11:54 PM
94 TA TT2S's Avatar
I have heard that if I just unplug the knock sensor it just pulls the timing out just to be safe....What can I do to disable it.....I know I can tune it out...But I have heard it still will pull timing....I have also heard that I can use my OBD-2 pcm (conversion for High Stall) with an obd-1 knock sensor...Can someone tell me if this will work?? Ion I believe it was you that told me that but could be wrong......
Old Nov 27, 2004 | 06:15 PM
Ryan94ZA4's Avatar
Re: Turning off knock sensor....
I would do whatever I could to figure out why it's pulling timing. Cutout, exhaust rattling, bad bearing in the alternator, etc. It's a bad thing to eliminate the knock sensor, IMHO.
Ryan
Old Nov 27, 2004 | 11:27 PM
94 TA TT2S's Avatar
Not alot of options when the header is setting on the k-member....
Old Nov 29, 2004 | 12:56 PM
Dan K's Avatar
motor mount maybe?
Old Nov 29, 2004 | 06:26 PM
94 TA TT2S's Avatar
I'll find out as I am pulling the motor over the winter....
Old Nov 30, 2004 | 11:13 AM
RE AND CHERYL's Avatar
As high as the LT1 compression is, I wouldn't disconnect or disable the knock sensor. IS the header making heavy contact, will denting the header releive the contact?
Old Nov 30, 2004 | 07:34 PM
94 TA TT2S's Avatar
actually the header has made itself a home against the k-member...Not sure how but the k-member has put a dent in the header......
Old Dec 3, 2004 | 01:35 AM
MEAN LT1's Avatar
I know what you mean, my passenger side header made a home on the k-member and has since made its own space between the header and k-member and the header it self.
HectorM52
Jul 30, 2017 11:46 AM
BigWil
Mar 29, 2015 12:24 PM
HectorM52
Mar 15, 2015 10:45 PM
formula79
26
Aug 5, 2002 12:21 PM
