Need some help converting .lt1 file to .bin file?
Old Nov 14, 2004 | 11:24 AM
T/A lt1's Avatar
I am working on a friends car with a CC306 and don't know too much about files. I found the file on Brent's site for the professionally tuned CC306 file but it's for edit and we use tunercat. I also saw that converter but don't know how to use it so if someone could help I would appreciate it. The file is heads&cam_306.lt1 that I would like to convert so let me know. thnaks Clint
Old Nov 14, 2004 | 11:27 AM
madwolf's Avatar
Re: Need some help converting .lt1 file to .bin file?
Tunercat should be able to read .lt1 files. When you open a file, you need to select LT1 FILES (*.lt1) in the file type section.
You can also go here and download the TuneConv.exe utility which will allow you to convert the file over to .bin format.
Old Nov 14, 2004 | 11:44 AM
T/A lt1's Avatar
Okay but how does that converter work? Do I just type in heads&cam_306.lt1 and press enter? I tried that and it didn't work?
Old Nov 14, 2004 | 11:45 AM
madwolf's Avatar
Rename your heads and cam file to something simple like 306hc.lt1 then try the same thing again.
Old Jan 2, 2006 | 10:53 AM
three83's Avatar
I've tried to go to the link to download TuneConv.exe and it seems the file isn't there. I also attempted to open the file with TunerCat and it's looking for a def file that I don't have. I'm going to look on there site to see if I can find the needed def file to open the .lt1 file. Does anyone have the tuneconv.exe file they could email to me? Three83byu@hotmail.com
Old Jan 2, 2006 | 08:47 PM
All you have to do is open it with Tunercat. It's that simple. Change the "files of type" on the file_open window to *.lt1.
Old Jan 8, 2006 | 09:24 PM
Hotwire's Avatar
you need the pcm_ee definition file that you will have to purchase from tunercats in order to work the software. If you email them, they will send you a copy to use w/ their evaluation software if you want it.
Old Jan 8, 2006 | 10:38 PM
Josh'95Z28conv's Avatar
Im having the same problem. I can open one of those lt1 files, but I cant make changes to them I want to change all the little things to match my setup, but I cant.
Old Jan 9, 2006 | 08:23 AM
Hotwire's Avatar
GO HERE: http://www.tunercat.com/tnr_desc/do_tc.html
Look to the left, click on supported ecms, scroll down to chevy cars, scroll to the bottom of that table, $EE, click on add to cart, supply information, receive ecm, live happy.
Old Jan 9, 2006 | 06:33 PM
I have that definition file. Why would buying another file help me out And since when did ordering a file get you an ecm
NewsBot
Jun 7, 2015 09:48 PM
NewsBot
May 28, 2015 12:50 PM
NewsBot
May 18, 2015 03:40 PM
NewsBot
May 15, 2015 08:10 AM
NewsBot
Mar 13, 2015 07:15 AM
