Cannot connect to PCM with lt1edit...Fuel pump not priming.
Ok..got everything back together and now I get no fuel. The changes made were lt4 heads/intake, new timing chain, remove heater core. The car will turn over but my fuel pump will not prime...hence..I'm not getting fuel. When I hooked up my laptop to look at the pcm I cannot communicate with it. Any ideas on what this could be.
I'm having the pcm tested today outside the car at thunder racing and I have another pcm I can try tonight to at least see if it activates the fuel pump. Any help would be grately appreciated. I've got the thunder shootout in 12 day and I need to get on the dyno to tune then to the track to dial the new setup in.
Tim
Tim
Re: Cannot connect to PCM with lt1edit...Fuel pump not priming.
Sounds like your PCM might be a gonner. When you turn your key on, do your fans stay on all the time? All your PCM connections are good? Grounds also? No blown fuses? Just some input...
Ken R 95Z
Ken R 95Z
had thunder racing test the pcm on a desktop system. He could connect and read it. Looks like i have a problem somewhere in my wiring system.
If the vats is removed from the car but still in the pcm will you not be able to connect to it?
Deadbolt24
Jan 19, 2015 01:29 PM
Jul 4, 2005 05:00 PM
