Need a "flagging" tool/option
Old Jan 3, 2005 | 12:59 AM
atljar's Avatar
Ive been tuning lt1s for about 2 years. Still learning things, but you know what would be the GREATEST tool imaginable...a flagging tool of sorts.
So when you are logging in freescan or dataMaster you could mouse click at anytime during the log, and it would mark or "flag" that frame. In that way, you could be driving along, feel a hesitation/cam surge whatever, and flag the exact time and readings when it occured.
Would make tuning SO much easier. You wouldnt have to try and watch the laptop and drive at the same time (common we have all done it).
Who wants to try a hack, it cant be that hard to implement. I dont know much about programming, but freescan would be the easier of the two i think. Just add an extra column to the CSV output and continuosly output '0' to it. When mouse/button is clicked, change the output to '1' or something like that. Holding the button would keep changing the next frame, and the next until released.
Old Jan 3, 2005 | 01:02 AM
turbo_Z's Avatar
Re: Need a "flagging" tool/option
Funny you should mention that. I was thinking exactly the same thing yesterday will I was driving around logging with datamaster.
Old Jan 7, 2005 | 12:53 PM
Mikey97Z's Avatar
Me too! I was thinking like a "bookmark" so you cn find that spot later. I use Datamaster. i can't believe they don't have this feature.
Old Jan 8, 2005 | 05:21 PM
StickMaster's Avatar
thats a good idea...ill get right on it
Old Jan 8, 2005 | 08:34 PM
atljar's Avatar
Awesome, which program do you plan on hacking?
Old Jan 9, 2005 | 02:56 AM
atljar's Avatar
FreeScan is in C++, AND i found the complete code...
http://cvs.sourceforge.net/viewcvs.py/freescan/#dirlist
Common comuter guys....
Old Jan 9, 2005 | 06:54 PM
You mean I found the code.....lol
Old Jan 10, 2005 | 03:28 PM
atljar's Avatar
Ya, I was the one who was nice enough to share it
Old Jan 14, 2005 | 06:55 PM
Well I almost got Freescan to compile but I need this file...if anyone can find it for me I would be greatly appreciative. "nafxcwd.lib"
Old Jan 14, 2005 | 08:40 PM
atljar's Avatar
Found this...
LNK1104: Cannot open file nafxcwd.lib
This error sometimes occurs when a project uses a class from the MFC but
the project settings don't explicitly tell the link editor to look in the MFC
libraries.
Go to Project --> Settings (Build --> Settings in Visual C++ 4.0). On the General tab check the box that says "Use MFC in a Shared DLL".
Old Jan 14, 2005 | 09:18 PM
Good deal jared, ill check that out when i get home
Old Jan 14, 2005 | 10:36 PM
Team ZR1's Avatar
The Ease scanner has that.
It has 6 F keys, each is a different color marker so while your recording you can hit a key and inject a color marker as many as you want and then when replaying the color markers show up so you instantly find the points of time you wanted.
Via the graph mode which shows 6 graphs at once the color markers show in each and if you do not want to see those markers you can turn then off.
Old Jan 15, 2005 | 12:19 AM
atljar's Avatar
Thanks for the reply, but i just checked out the price list for EASE scan. I about fell over. lol. I think it would be cheaper to hire a programmer to fix FreeScan than it would be to buy the Ease scan
Old Jan 15, 2005 | 09:55 AM
Team ZR1's Avatar
Not sure what cost your looking at but the Ease scanner is $350 which comes with the software, cables and CAN/GMLAN interface.
Old Jan 15, 2005 | 07:04 PM
Gimme $350 an ill MAKE you a cable and software.
