2bar+ support for DA cars.
Old Dec 7, 2004 | 11:17 PM
Gimpster's Avatar
I've been working on definition file for $DA-B as I've called it. This is to make things a little less confusing (for DA owners anyway) when rescaling for 2bar on a stock rom. Its pretty much done, but not sure on the legality of releasing it since its based on the $DA TunerCat sells.
Also I've been working on hacking the ROM to rescale the map voltages & tables for better resolution.. here is what I've done/figured out so far:
1.) I've found the map scalars, but havnt figured out the formula yet.
2.) I have successfully moved the fuel/timing tables (normal and ext) to an unpopulated area of the ROM. I did this so that I can eventually expand them 5-6 columns for boost instead of losing resolution on the vacuum side of things.
When the column expansion is complete, I will update my $DA-B definition ... I think at that point I'll be in a legal position to share the definition, but need to email TunerCat on that.
Thats all I've had time to work on, but... making progress. Who knows, maybe eventually i'll finish this work... and trust me when I do finish I'll release the info to DA owners free of charge. I figure at the very least you can take the info, modify your own ROM and make your own definition if I'm not allowed to share mine. I have no intentions of doing this for EE, as I own a 93.. speed density owns you.
If anyone has any info on GM map scalar formulas... lemme know.
Anyway, just thought I'd share!
Old Dec 8, 2004 | 12:11 AM
tjwong's Avatar
Re: 2bar+ support for DA cars.
Cool! Keep us tuned in of your efforts. I am sure that TC would not mind. I share several files with him all the time. Just pay him the courtesy of emailing him and let him know whats up
Old Dec 8, 2004 | 02:36 PM
Fastbird93's Avatar
Shoot chips@pcmforless a message as I do believe he's got the whole swap down for moving to a 2Bar sensor on a 93.
Old Dec 8, 2004 | 03:18 PM
Gimpster's Avatar
Well this whole thing has started because I bought (am in the process of actually) his (Rooster93v8's) Eaton setup. I hack Honda/mitsu stuff and bought this GM... so figuring stuff out on my own is always nice
I know he has some 2bar stuff figured out, but I don't want to step on his toes or release any tunes/info proprietary to his business.
Old Dec 8, 2004 | 03:22 PM
Fastbird93's Avatar
Gotcha. You're going to be really pleased with that Eaton setup. That thing is freakin cool.
Old Dec 8, 2004 | 03:25 PM
Gimpster's Avatar
I'm EXTREMELY excited to get the Eaton setup... thats all I have to say on that
Old Dec 11, 2004 | 02:56 PM
shox9879's Avatar
hey i have a super charger @ 6-7 psi and 37lb lucas injectors and need a 2bar tune does any body want to share a program/tune i have moates programer just email the bins files thanks any help will be very helpful
Old Dec 12, 2004 | 10:38 PM
Highlander's Avatar
Care to work the same thing for 94+?
Old Dec 16, 2004 | 12:42 AM
Highlander's Avatar
Updates on this
David Dempsey
Mar 12, 2016 12:42 AM
CARiD
Sep 30, 2015 05:44 AM
alliance12364
Sep 23, 2015 12:40 PM
