WOT timing on a blown stock LT1
Old Dec 26, 2004 | 02:16 PM
Dave93Z's Avatar
What kind of maximum timing advance is typical for a stock LT1 with 6-7 PSI of intercooled boost?
Stock 96 Impala SS LT1 engine
P-1SC ProCharger
28-29 degrees at WOT
I move about 370 GPS of air by the time it shifts around 5500 RPM.
OBD-I PCM (converted to use the OBD-II knock sensors)
LT4 Knock Module already installed
93 octane
I'm getting frequent knock counts and resulting KR that goes away if I pull a good amount of timing with my BTM. If I'm should be running a lot less WOT timing than I currently am, great.. I'll just have it tuned accordingly. If I should be able to run 28-29 degrees of timing at WOT, I need to figure out
If I run the full timing the car hauls. Naturally, with the BTM pulling lots of timing the car isn't quite as quick as far as my butt-o-meter is concerned.
Just wondering how much timing (without any resulting KR) people have known to be able to run on a stock LT1 with 93 octance and a similar 6-7 PSI of maximum boost.
Thanks Dave
Old Dec 26, 2004 | 02:33 PM
Dave93Z's Avatar
Re: WOT timing on a blown stock LT1
Also noticed that I'm always running in long term block 131 at WOT. Don't know if that indicates anything in particular...
Old Dec 28, 2004 | 01:56 PM
Dave93Z's Avatar
Anyone?
Would it be normal to expect knock retard from the PCM at 28-29 degrees of timing with the above setup?
Old Dec 28, 2004 | 03:59 PM
rskrause's Avatar
Moderator
I would not use more than 24 degrees.
Rich
Old Dec 30, 2004 | 11:33 AM
slimdawson's Avatar
Also, a 131 is a bit lean before compensation. The a/f is not at its potential.
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
1LEThumper
Jul 14, 2003 12:45 PM
