datamaster....what is CCP DC
Re: datamaster....what is CCP DC
is that the same as the air pump, becuase if it is. its not to come on until 150 degrees C.
but if it not the charcol canister purge. then how do i turn it off.
Originally Posted by ROOSTER93V8
Why do you want to turn it off.
It doesn't hurt the performance of the car, it doesn't get in the way... It just saves our enviroment from gas vapors..
becuase if this is on at any percentage right before you got wot (pe mode) it will use cell 15, even if the blms are below 128, and it adds fuel to your pe tables, becuase it adds what ever correction factor it has stored in cell 15, i want to use cell 18 no added fuel.
note: and it will still use cell 15 even if you use the wot blm locker
mrmint69
03-02-2008 10:04 PM
canbaufo
06-02-2005 10:17 PM
