Help with check engine codes
Old Jan 8, 2005 | 01:58 PM
D Guess's Avatar
My 96 z28 is throwing a 1641 & 1642 code. Where can I look these up?
The check engine light came on. My cooling fans will not turn on. I checked the fuses and the cooling fan 20A fuse in the engine bay was blown. I replaced and re-set the computer. The fuse blew again and the check engine light came back on.
I had autozone check codes. They said found 1641 & 1642 error code. One of the codes for for "air injection valve". The scanner wouldn't tell what the other code was. Anybody have any ideas? Would a faulty air injection valve cause the fuse to blow?
Thank you.
Old Jan 8, 2005 | 02:35 PM
moparman's Avatar
Re: Help with check engine codes
1641 - Problem with fan control relay 1 circuit
1642 - Problem with fan control relay 2 and 3 circuits
Maybe fuse or harness?
Old Jan 9, 2005 | 08:13 AM
D Guess's Avatar
Thanks. I'll check the harness first.
bfmv13trivium
Jan 14, 2015 09:57 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
