need LS1 edit help asap...gotta set my injector tables back closer to stock!
Old Oct 25, 2004 | 02:27 PM
Timberwolf's Avatar
I did a bunch of mods, one of them including 36# injectors. I since found out there was no need for such a big injector, and no matter how much tuning I did, I couldn't get this thing running up to par.
So I put the stockers back in, but need to know how to reset the tables for the smaller injectors. the car isn't stock, so I don't want to go back to stock tables totally, but I can fine tune if need be. just gotta get some fuel back into this thing.
The car is a 99 as are the stock injectors (obviously). The ones I had in there were 36# ford injectors. So should I just scale injector rate according tot he same % that I changed the actual injectors? Meaning, I put injectors in that are 1/3 smaller, so should I increase the flow tables by 1/3rd accordingly?
BTW, I'm using ls1 edit to tune if that helps your recommendations.
Thanks in advance!
Jlo
Feb 3, 2015 09:41 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
ddr698
Jan 9, 2015 10:05 AM
rockync7
Jan 1, 2015 05:10 AM
Bando
Aug 2, 2002 02:18 PM
