auto comp in manual car
Old Nov 25, 2004 | 12:45 AM
Fast Orange's Avatar
i have a 94 firebird m6 and i put a 94a4 computer in it to eliminate the old governer... every since then my car will NOT run under load with the MAF plugged in.. at idle its all good.. but under load it spits and sputters.. unplugg the MAF and it runs WAY better than the factory comp but with a slight miss hear and there at idle... is there something about the odb1 that isnt compatable between the m6 and a4.. already replaced the MAF thinking it was bad..
Old Nov 25, 2004 | 02:49 AM
bunker's Avatar
Re: auto comp in manual car
No it won't run right when you come to a stop because the IAC won't work properly as the speed will be off. Also, the reverse will be locked out unless you forse it in.
Old Nov 25, 2004 | 10:43 AM
thats just it though.. it runs extremely good WOT with out the MAF plugged in.. idles fine with the MAF plugged in but wont run under WOT.. yes you are right bout the speedo and the reverse lock out..
so with the MAF plugged in your saying that under a load the IAC isnt working correctly because the speedo is off?
Old Nov 25, 2004 | 11:00 AM
Dan K's Avatar
I'm just not sure what the point of this even was?
All you had to do was have the computer re-programmed, right?
Old Nov 25, 2004 | 11:35 AM
well if you have a car without a governer sitting next to yours it sure was easy and cheap.. i was just wonder what was up with the MAF kick..
Old Nov 25, 2004 | 08:32 PM
Dan K's Avatar
What kind of governor are you referring to? A mph limiter in the ECM?
Old Nov 25, 2004 | 09:25 PM
MEAN LT1's Avatar
Ehh, why not just have the computer reflashed to an M6program.
Old Nov 26, 2004 | 09:18 AM
Dan K's Avatar
That's what I'm not understanding?
Old Nov 26, 2004 | 08:40 PM
well there isnt anyone around here.. i like the fuel map on the auto comp.. im going to have a whole new burn eventually and dont see the point in paying for two burns... and yes i was refering to the mph limiter.. i just was wondering why it wont run with the MAF plugged in but it runs like a striped *** ape with it unplugged.. just curiosity.. i drive the car everyday.. no problems..as long as the MAF is unplugged..
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Snoman73
Nov 17, 2014 07:22 PM
