Running take piping: ABS is completely in the way... need help
Old Jul 19, 2003 | 04:02 PM
Jesse_Boyer's Avatar
basically, I'm building intercooler piping and I can't get it to the intake elbow. The ABS unit is completely in the way.
First option: remove ABS unit. How involved is it? What fittings are needed.
Find a way to the intake.
Personally, I like the latter option, but I don't see how it's possible.
Jesse
Old Jul 19, 2003 | 04:08 PM
http://groups.msn.com/JesseBoyer/misc.msnw?Page=1
Pictures are above. Let me know if you've got ideas
Old Jul 19, 2003 | 04:29 PM
Brandy's Avatar
I just ditched the ABS on my car, less weight and more room As far as fittings go you need a way to make the two lines from the master cylinder split into 4 lines. I bought two of the Hurst line lock install kits and made it work. You need a pretty good flaring kit as well.
Old Jul 19, 2003 | 08:23 PM
VX355's Avatar
Hey Brandy, who made your heater delete plate that you have in your car now? Also, what kind of work was it getting out ( removal inside of the car, etc.)? My gawd that engine bay is clean as hell, good job.
Thanks,
Old Jul 19, 2003 | 08:46 PM
dynomight's Avatar
Jesse, i can email you pics of my setup. The intercooler is located under the ds headlamp. Very similar to yours, and i have it apart right now for a new cooler. By fabbing an alternate radiator shroud, you can get a little room there. I have a procharger TB elbow, which is smaller in diameter than the MAF (which i have under my ps headlamp now). Plenty of clearance to the hood. Let me know if i can help more. Good luck...
Old Jul 19, 2003 | 09:16 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
I trimmed back the fan shroud in that area and also used 3 inch pipe past the ABS. It is VERY tight, but it fits.
Old Jul 20, 2003 | 01:55 PM
Brandy's Avatar
Thanks,
A friend of mine made it with a plasma cutter. It's a bear to get the dash out, good thing I didn't have to do it http://www.simplequickracing.com pretty much does all of the grunt work for me now since I've "retired" from dirty work.
DirtyDaveW
Dec 1, 2016 05:37 PM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
Collector Car
Jan 5, 2015 10:58 AM
