Spark plugs and gaps.....lets hear it...
What spark plugs do you run...and what do you gap them at so the spark does not get blown out..
and what kind of boost are you running.....
I run NGK Tr-6's gaped at .32 ........ however I do still have three that are gaped at .40 ..#3 ,#5 and #7.they are a bitch to get to....and I think thats were my high rpm missing problem is coming from.....
Ok I was running 104's gapet at 37 with 14LB of boost and a MSD6A But i added a 50 shot of nitrous and whent to 103's gaped at 35 with 14LB of boost. The rest is in the down below.E-mail if you have any questions. troy
Originally posted by Sparkz28
So how come you went with NGK BPR11ES ........ whats the difference between that plug and the NGK R tr-6?
Rich Krause
Originally posted by rskrause
It's the wrong size for an LTx casting, I am using AFR's. But the rationale for the plug is that it is very cold - 5 heat ranges colder than the TR-6. Interstingly, I have had no problems with fouling.
Rich Krause
Rich Krause
I must guess (don't like to assume
) that you are also using one of the ignition boxes too ? MSD , Crane , etc.
Originally posted by bowtiepwr
>Is your car used everyday as a "daily driver " ?
Rich Krause
I run Autolite 103's gapped at .035. I run these on AFR heads too.
Rich,
What do you mean your plugs are for AFR heads? I didn't know there was a difference in the plugs from the LTx castings and AFR's. Can you elaborate on this?
Bill
Rich,
Bill
Rich,
Bill
Rich,
Bill
Rich Krause
i was reading a while back where people were having problems while running the MSD6AL and the plugs gapped at .032-.035, they were stating that the optis were burning up, or just going bad. have you guys had any of these problems. what do you think about the accell box, good and bad.... thanks
