header efficency
Old Jul 7, 2003 | 11:26 PM
stevem's Avatar
header efficency
how important is flow before the turbo.
thanks guys
you guys have some awesome cars
Old Jul 8, 2003 | 08:57 AM
NoSlix's Avatar
You would be surprised at how unimportant it would be. You can easily make 200hp per cylinder with 1 5/8 ID header tubing. I know of one 4 cylinder SVO motor making 800hp with 1 1/2 ID tubing. For midsize V8s wanting to make up to 1000hp, we usually use 1 5/8 ID headers into 2 1/4" crossover pipes and merge those pipes into a collector at the turbine flange. You can decrease spool up time by building a true merge collector at the turbine housing also.
Old Jul 8, 2003 | 10:40 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Do you have any pics of what a merge collector at the turbine inlet flange would look like?
Thanks!
Old Jul 9, 2003 | 01:37 PM
Mr. Z28 73/97's Avatar
Intinid8
I think Burns Stainless makes a true merge collector that the turbo mounts to, I think I saw their ad in Turbo magazine.
Old Jul 9, 2003 | 01:49 PM
NoSlix's Avatar
I'll try and post a picture of the Y pipe I made for the last turbo system I built which had two 2.5" crossover pipes merging into the collector. Burns stuff is sweet, but WAAAAYYYYYY expensive. Actually, they make merge header collectors with a V band attachment. You still have to make pipes to join the collector into the turbo and that's where I build another merge.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
