8.97s @ 152 mph
Old Aug 8, 2003 | 06:29 PM
Fickle's Avatar
8.97s @ 152 mph
http://www.procharger.com/chevy.shtml
No wonder my friends call me Fickle. It's hard to decide what you want to build when there are SO many options....That car is just plain sick...and I'm sure it's reasonable as far as money spent to go that fast....
And the sweetest part is, the guys would be puzzled when you pull up to the pump and fill her up. I think my mind has changed for the 100th time now. Geez, I need to stop reading... First it was a 355, then a 383, then a 434, then a BB, now this?????
Old Aug 9, 2003 | 10:19 AM
EDS Z28's Avatar
Hmm, interesting how a carb makes more power with a blower than efi because of the cooling effect. But I think the efi setup is more street friendly.
Old Aug 9, 2003 | 01:43 PM
89ProchargedROC's Avatar
i dont know man, thats kinda crappy for an F2. I think they might have some numbers wrong.....
i mean that guy that sold his yellowz28, i think his name was camarojcb or something like that, had a 454 with a D1 and if i remember right made over 1000hp on pump
That F2 is capable of way more than that....i believe they made that power but i bet that psi rating is wrong. 24psi outta a F2 would made A LOT more power
Old Aug 9, 2003 | 04:35 PM
rskrause's Avatar
Moderator
I have no idea WTF they were trying to say about crank angles and hp. Yes, ideally peak cylinder pressure should occur about 20-30 degrees ATDC, but what's that have to with a blower vs. na vs. nitrous? The main determinate of where peak cylinder pressure occurs is ignition timing, AFAIK.
Rich Krause
Old Aug 10, 2003 | 03:05 PM
1994B4C's Avatar
That article pretty much sucks especially the whole thing about the crankshaft angle. The reason the piston is pushed down in the first place is because there is greater pressure on the top of it than there is at the bottom. So if you see high cylinder pressure at the top of the stroke its not going to make you lose power. That pressure is still gonna be there except you have taken advantage of the pressure 30 (or whatever they were saying) degrees more because it started earlier in the stroke.
95chwagon
Oct 16, 2015 12:24 PM
4586
Sep 27, 2015 01:55 PM
MDZ28
11
Sep 24, 2015 09:15 AM
NewsBot
Sep 14, 2015 09:20 AM
mmf_1013
Sep 12, 2015 08:56 PM
