Running out of fuel, fuel pump?
I've been trying to tune my car as of late. I've been using Data master to log some pass. Everything looks good up till 5700. The 02's start falling bad. I have a Inline NOS pump, but still have a stock intank. I just bought a walbro 255 high volume intank pump inhopes that this will cure the problem. The question I have is should I leave the inline pump in or should I remove it. I was told that it is a restriction when I step up the the 255lph. My current set is a 383, 42#svo, T-Trim w/aftercooler,11#'s of boost.I will also be adding a 75 shot for extra cooling effect
. But will not run the nitrous until I get the fuel problem Corrected.
Any help or suggestions would be great.
Thanks GS355
. But will not run the nitrous until I get the fuel problem Corrected. Any help or suggestions would be great.
Thanks GS355
Originally posted by IDOXLR8
I would probably stick a twin intank setup and get rid of you inline pump. I made 705 rwhp with this setup.
could you tell us more about the twin intank pump setup that you have..................I also have a stock intank pump and the in-line pump that cam with my procharger and I dont realy like this setup.........because my stock fuel pump has 98,000 miles on it and I dont want it to crap out one day when Im making boost....
thanks
