Powerdyne internal belt?
Old Jun 30, 2003 | 12:04 PM
Maldo's Avatar
Hi guys what is the width of the internal Powerdyne belt? (in mm)
Old Jun 30, 2003 | 05:52 PM
MislMan's Avatar
This is "old" data taken from the Mustang board at corral.net
Hope it helps!
Belts:
Gates Powergrip HTD 375 5M (Kevlar)
Standard 32-36mm 375 5M (Fiberglass)
Powerdyne rebuild
Belt info
IPS
7739 Tonja Ct.
Byron Center, MI 49315
Paypal accepted
E-mail Matt at ForcepowerEng@aol.com
Belt is $40.00 plus $6.00 shipping anywhere.
“Gates” Numbers on belt: 3755M also 421MC
Bearings
Lower 6202FCCB $59.20 for 2 in ceramic
Upper 6205 $16.00 for 2 in steel w/krytox grease
3 day UPS $14.45
$89.65 total for me
Paypal accepted
Forcepower - My number is 616-437-2296. Matt
Later ... Larry S.
Old Jun 30, 2003 | 09:32 PM
Maldo's Avatar
[QUOTE]Originally posted by MislMan
[B]This is "old" data taken from the Mustang board at corral.net
Hope it helps!
Belts:
thanks but when i called gates they need the width of the belt in mm to order
Old Jul 1, 2003 | 08:10 AM
Erik 94TransAm's Avatar
Stock width is 33mm, i don't know if gates has one, you may have to go 35mm wide.
Its 375mm long w/ a 5mm pitch. So, 375 x 35 x 5. Fiberglass belts are $11, kevlar are around $20 from local dealers.
Big bearing is a S205SS, small is S202SS. $15 and $10 respectivly from local dealers.
Old Jul 1, 2003 | 10:16 AM
Maldo's Avatar
Cool thanks you very much for this info (this is a big help).
I will contact Gates to see if they can get a belt like this to me
Because i know they make one that is very similar then but i am not sure if it is 33mm wide
I think a gate makes up to 22 or 25 mm wide in this belt configuration.
Has any one tried this?
I know the other guy sells them but he only take paypal or check which take a long time I have a local Gates supply warehouse that can have the belt to me the next day.
Old Jul 1, 2003 | 12:35 PM
Depends who you're buying from.
tip87gt@aol.com sells a 35mm wide kevlar gates belt that he spray paints black so hopefully you won't figure out the size. I'd try and stay above 30mm for strength sake.
Old Jul 1, 2003 | 12:40 PM
Maldo's Avatar
This Belt is from “Gates”:
I ordered it from a suppler over in my area.
If this works i will let you guys know. This would be nice becasue these belts are dirt cheap and i could get them for allot less then what most are selling it for.
68camaroboltz
Oct 5, 2015 01:46 PM
HAWG
Sep 25, 2015 11:41 AM
95blkss
Sep 22, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
