Turbotech kit with solid Moroso motor mounts
Old Jul 20, 2003 | 02:13 PM
Brandy's Avatar
Well in case noone has tried it yet the steering shaft hits the header really badly. Has anyone ever fixed the problem?
I've considered buying an aftermarket K member and a manual rack, just a manual rack, one of the Flaming River military spec u-joints or just dinging the header and grinding down the coupler. Any other ideas? Does anyone offer a better steering linkage?
I tried just grinding down the coupler but I'd have to take alot off. I also considered just spacing up the engine mounts but thats nearly as ghetto as grinding the coupler.
Old Jul 20, 2003 | 07:07 PM
Cmarsh93z's Avatar
Cool
Whatever you do brandy, im sure it will look good
Chris
Old Jul 20, 2003 | 08:47 PM
Brandy's Avatar
Thanks for your usual constructive comment. Btw I see the domain in your signature is available, might want to register it before someone else does
Old Jul 21, 2003 | 08:22 AM
Cmarsh93z's Avatar
Ahh, just on old website...you can have it if you want
Chris
Old Jul 21, 2003 | 05:08 PM
zturbo's Avatar
I ran into this problem with the moroso mounts Had to modify the back of the tt manifold to fit around the steering shaft.. Sorry no pics as the system is long gone.
If i did it over again I would just get a piece of alum to the thickness to clear and mill it to fit under your motor mount between the K member and the mount. Will be light, look fine and give you the correct spacing.
Steven
Old Jul 21, 2003 | 06:01 PM
Brandy's Avatar
So does it clear with a good aftermarket K-member? I need one anyways and this would make for a good excuse to do so
Old Jul 21, 2003 | 06:04 PM
zturbo's Avatar
In all honesty I don't see it making much differance as the engine sits in the same spot.. I did not get my tubular K member till i got rid of my turbo technology kit..
Steven
Old Jul 28, 2003 | 08:22 PM
Dave Feerst's Avatar
if its that metal clip that strengthens the rag joint that is hitting you can bend it straight sideways as opposed to being bent back toward the firewall, thats what I had to do to make my headers work.
Old Jul 28, 2003 | 09:55 PM
Brandy's Avatar
No, it's actually the u joint itself. Thanks for the suggestion though. The Flaming river joint is going to be ordered this weekend, if that doesn't work then the mounts are going to be shimmed.
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jul 30, 2017 11:46 AM
Z28STYLE23
Aug 17, 2002 07:40 PM
Z28STYLE23
Aug 4, 2002 03:30 AM
Z28STYLE23
Jul 19, 2002 11:29 PM
