Q's About ATI P600B
Old Aug 4, 2003 | 08:52 PM
LPELS1's Avatar
Q's About ATI P600B
yeah, this guy here in town is selling a ATI P600B with a 6 10 and 18 # pullies. I know ill just use the 6 but do you think it will work on an ls1? and if so, is it worth 1,500 dollars including an innercooler? thanks for your help in advance.
Old Aug 5, 2003 | 12:34 AM
ATMINF's Avatar
Find out what the original kit was for, and how long the blower has been used. Sometimes it can be a great deal, if most parts are there and it is in good condition. If you know the guy and he can be trusted I say its not bad. You do have to understand though it is going to be alot of work to fab up new brackets and test fit new hoses, etc.... to make the system work if its not for your application. If you have the time and skill, go with it, if not just by a proper kit for your car so you have less fabication to do.
Old Aug 5, 2003 | 12:38 AM
LPELS1's Avatar
thanks for the help, every bit is appreciated
Old Aug 5, 2003 | 07:40 AM
IDOXLR8's Avatar
I am pretty sure that ATI does not offer an 18# pulley for a P600B.
Old Aug 5, 2003 | 09:04 AM
MEAN LT1's Avatar
ATI doesnt sell or recomend spinnign the p600 that high. They do sell a 15# pulley for the kit but do not recomend it. Id say the highest pulley I would put on there is a 12# as people have had good luck with it.
Old Aug 5, 2003 | 12:00 PM
LPELS1's Avatar
thanks guys, it said 18, but chances are its not, anyways, i would most likely only use that 6#, because i only want a little boost. keep em coming.
jesse
Old Aug 5, 2003 | 07:49 PM
LPELS1's Avatar
Well, i went ahead and bought it today. it looks in good condition. do you think i could get the bracket and stuff from ATI? i noticed the unit is gonna be fun to install because the intercooler is one peice. but i think i found a spot for it. You guys helped a lot. Next time i post a message to this it will be about me not being able to get it to work right talk to you then.
Old Aug 6, 2003 | 07:32 AM
IDOXLR8's Avatar
You paid 1500 for this kit and it is not complete. Do you know by any chance how many miles were on the blower? Before agreeing to buy it I would had sent it out to make sure the compressor is in good shape. Good luck on the install.
Old Aug 6, 2003 | 10:47 AM
LPELS1's Avatar
where would i send it to have someone check it? The only thing its missing is a fuel pump and i am going in with a few buddies of mine to get LS1 edit to solve the tuning problem. There is a lot of tubing with it, but i would like to either order new or have some custom made. i would just like it to look nicer. as far as the brackets are concerned, i can most likely have my friend make one, if i knew what it looked like. does anyone have any pics of install i could look at to find out what i need? thanks
Jesse
Old Aug 6, 2003 | 10:48 AM
LPELS1's Avatar
by the way, The kit comes with The P600B, an Intercooler, tubing, brackets, oil lines and oil cooler, and a lot of other stuff in this big box.
Old Aug 6, 2003 | 10:57 AM
LPELS1's Avatar
and do you think i can run the 6# pully without worrying about the bottom end of the motor if i keep it tuned?
Old Aug 6, 2003 | 11:48 AM
IDOXLR8's Avatar
You can always send the blower back to ATI to have them inspect it. I think it cost 75.00 but I could be wrong. I am not sure for an LS1 but for an LT1 the kit comes with a blower, intercooler and piping, blower bracket with tensioner, oil lines, bypass valve and inline fuel pump.
6lbs is a good starting point but remember you motor can go at anytime. It is very unpredictable. I would recommend buying an LS1 Scanmaster and an MSD 6BTM to help monitor your car.
Old Aug 6, 2003 | 01:45 PM
LPELS1's Avatar
that will come in handy, thanks
Red_94Formula
Mar 7, 2015 09:21 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
Rybar
Jan 30, 2003 10:09 PM
SC97TA
Sep 15, 2002 01:10 AM
Black97Z
New England Area
Jun 18, 2002 09:39 AM
