Turbo charger help
Old Jul 2, 2003 | 03:59 PM
kaoticcamaross's Avatar
Turbo charger help
I have a 95 z28 with just a few mods. I wanted to know if theres a supercharger you can put on a 95 z28 without having to replace to many stock parts such as drive shaft and so on an still beable to get into the 11's.
Old Jul 2, 2003 | 04:49 PM
96TurboTA's Avatar
Your post says "Turbocharger help", but your asking about superchargers, which is it?
Old Jul 2, 2003 | 05:48 PM
Sorry It's been a long day. I meant to say turbo.
Old Jul 2, 2003 | 09:54 PM
SMOKNZ's Avatar
As long as you don't run slicks the stock parts will last you a while. I have a friend that ran the stock rear and driveshaft even with slicks and an auto with no problems. If your a stick shift car avoid slicks and big clutch dumps, the big torque down low likes to bend and twist things up a bit.
Old Jul 3, 2003 | 09:18 AM
Ok so I could buy a turbo and all i would need is the turbo set up and the intercooler. My stock gears, driveshaft, suspension, and lt1 will be ok. Just to make sure I'm getting this right. Also how much psi would i need to keep it around.
Old Jul 3, 2003 | 09:17 PM
SMOKNZ's Avatar
I ran mine with the stock rear and driveshaft for a year or so before i went to the 9" rearend. It wasn't really needed but was something i felt i would eventually need. That was on the stock motor too. If you keep it tuned right it can live a while. The conscensus seems to be no more than 6 psi non-intercooled, and 8 psi intercooled. But even then guys break their pistons, so if your stepping up to forced induction always be prepared for the inevitable.
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
