Holley roots type
Holley roots type
Was browsing thier site and noticed most of the blowers like this they offer have a note by them that says they do not work with 93 and later lt1 heads but a couple didnt, just wondering if they work on the lt1 engine itself it was the 250 pro-street I was looking at that didnt say it wouldnt work with the lt1 adn I think it was a low profile one as well for hood clearance... Also I was wondering if its posible to adapt a superchargeer from another car say a supercharged 3800 from a, correct me if im wrong, GTP? or maybe 2 of them since its probably a smaller supercharger... I am aware some of these questions may be ignorant but I didnt see them discussed anywhere so I thought ide throw it out there.
try these posts
http://web.camaross.com/forums/showt...ighlight=eaton
Do some searches for Rooster93v8. He ended up using an Eaton m112 and has the car running. I don't think it is finished yet.
Good Luck
Good Luck
Ahhh.......Cool.
Hey Rooster I have a few questions for ya'
If I remember right, I saw some posts that you made talking about an fmu. Why are you running an fmu with pcmforless tuning? I thought Brian could tune for a SC so that you didn't need an fmu. I am just curious what you have done to get the fuel/pcm to work right.
Secondly, how would a fella reproduce an intake like yours? I would really like to do something similar, but my fabrication skills don't exist.
And I am not real sure how I would go about giving someone specs or trusting someone to do this. There aren't a lot of shops that could do this sort of thing around here. If I remember right, didn't you end up having yours made somewhere? Would they be able to make another?
How many pounds of boost does that thing put out?
I have a GTP with an M90 and the torque and instant boost those eatons make is very nice
I am just kicking this around, but any info. you could provide would be great.
And I am not real sure how I would go about giving someone specs or trusting someone to do this. There aren't a lot of shops that could do this sort of thing around here. If I remember right, didn't you end up having yours made somewhere? Would they be able to make another?How many pounds of boost does that thing put out?
Originally posted by JWBerk94Z
Ahhh.......Cool.
I work with Bryan, I do all the chip cars and he does all the flash stuff. I could have made it work without a FMU if the car was mass air but this car is speed density and it is totally blind as to how much airflow is coming into the motor past 1 atm. For ultra smooth performance and driveablity I don't see any other way to program this thing besides swaping to a 2 bar speed density system.
If you can't weld and don't have access to a machine shop than i would not reccomend this. It was cheap for me to do cause i did it all myself. I built the lower intake myself and built a upper out of steel. I didn't like the steel intake so i brought it to someone who copied the exact same design in 1/8 aluminum. I probally could have made one out of aluminum too but i didn't feel like messing with such thin stuff without a TIG.
7psi I can't tell when it starts because as soon as i get the gas its there. No boost building at all
Ahhh.......Cool.
And I am not real sure how I would go about giving someone specs or trusting someone to do this. There aren't a lot of shops that could do this sort of thing around here. If I remember right, didn't you end up having yours made somewhere? Would they be able to make another?If you can't weld and don't have access to a machine shop than i would not reccomend this. It was cheap for me to do cause i did it all myself. I built the lower intake myself and built a upper out of steel. I didn't like the steel intake so i brought it to someone who copied the exact same design in 1/8 aluminum. I probally could have made one out of aluminum too but i didn't feel like messing with such thin stuff without a TIG.
CARiD
Sep 30, 2015 05:44 AM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
