breathers necessary on s/c'ed motor?
Old Aug 4, 2003 | 06:44 PM
dynomight's Avatar
I just bought summit aluminum valve covers. In their present form, they wont work. I have to hog out the front of the pass. side to clear the alternator. And they also have no fill holes or breather holes. I am going to drill into the pass. side cover for the breather. My question is should i put breathers on both sides, or is one enough?
Old Aug 4, 2003 | 08:28 PM
BPS's Avatar
BPS
I think you can get a breather that will go onto the oil filler cap (so I'd combine the 2) , as well I also thinK the pcv allows the drivers side to breath so it's not necessary to mess around with that side.
Old Aug 4, 2003 | 09:01 PM
dynomight's Avatar
The vc's came blank. Fabbing required. I am drilling my own holes. They are 4" tall, which will require a little hogging out to accomodate the alternator. I am drilling a hole in the passenger side vc as i already have a breather there. I need to know if it would hurt, help, or no change to install a breather on the driver side as well. Thanks for the help...
Old Aug 4, 2003 | 11:34 PM
97TA-WS6-Con's Avatar
Yes two breathers is a good thing. However, I bought some aluminum valve covers on ebay that were notched for the alternator for about $90.
alex5366
Mar 27, 2015 03:30 PM
HectorM52
Jan 30, 2015 11:34 PM
jrp4uc
43
Sep 18, 2002 08:26 PM
