Z28 runs bad after solid intake install
Old Jun 28, 2003 | 08:43 PM
96Z28/93TA's Avatar
Thumbs down Z28 runs bad after solid intake install
I just had a muffler shop install a 3.5" solid intake for my Vortech s-trim, they also hollowed out my cat converter. When I take off from a stop the car pulls hard until 3500 rpms, then it falls on its face almost like im hitting a rev limiter. My Crane ignition retard **** lights up when it happens, but I checked for knock retard with a scan tool and it checked out ok. Checked my fuel filter its ok. Is 3.5" too big of a intake pipe?? any ideas
Old Jun 28, 2003 | 08:45 PM
96Z28/93TA's Avatar
also it only happens when I punch the throttle, if I ease into it it runs ok. WOT it falls on its face until I shift then will do it again in every gear when it hits around 3500rpms. The car is a 96Z28 with a 6-speed.
Old Jun 28, 2003 | 09:28 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
2 things I can think of happening.
- For some reason the pipe is restricting airflow? (Maybe an extreme tight radius 'cheated' bend right off of the blower)
- You are drawing through the MAF (maf is pre-blower), and there is an air leak, or MAF sensor wires were damaged during the install.
Old Jun 28, 2003 | 10:21 PM
96Z28/93TA's Avatar
I already checked the MAF wiring and for vacuum leaks, but I will pull the pipe off and check for a restriction. thanks for your input
Old Jun 29, 2003 | 09:01 PM
96Z28/93TA's Avatar
another this is...that I eliminated the PCV pipe from the Intake tube to the valve cover. Would this make any difference??
Old Jun 30, 2003 | 09:33 AM
96Z28/93TA's Avatar
TTT
Old Jun 30, 2003 | 10:30 AM
95 Silver TA's Avatar
Are you saying that you pulled your PCV line off the intake and Valve cover and just plugged up the valve cover. I am not sure that would cause your problem but you DO need to VENT that off of the valve cover. I used a line from the Valve cover and vented it to atompshere otherwise you would have too much pressure in the crank case.
Thanks,
Claude
Old Jun 30, 2003 | 05:53 PM
96Z28/93TA's Avatar
95 SilverTA.. I just removed it from the SC intake pipe and put a little filter on the valve cover.
I pulled off the cold air pipe today and checked it out. I looks really good with no restrictions. I wonder if 3.5" intake pipe is too big for 6# of boost. I am going to put the stock intake ducting back on to see if my problem goes away.
Noenav
Mar 1, 2019 07:38 AM
Noenav
Dec 6, 2014 07:35 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
