How does a FMU recalibrator work?
I've got way to much fuel with my FMU.. Its going max rich at 4000 rpm and not pulling beyond that because of it (I guess)
Has anyone looked at the recalibration kits Vortech sells? I hate to wait a week for a few washers and pay $40 for it
Re: How does a FMU recalibrator work?
good luck
Yeah, I'll tell you that a centrifical is gravy compared to tuning this thing. tuning a forced induction 1 bar system isn't as easy as a MAF car by any means.
Its almost like starting from scratch, everything has to be redone and big time...
I'm sure that the thing is going to rich, its choking the motor too much.. Problem is I bought a used FMU with this project and have no idea what ratio it turely is.
I've got to use a FMU with this car, its 1 bar speed density
You're sure the high fuel pressure isn't causing the injectors to lock up?
The ATI FMUs use a bleeder screw where the vacum hose hooks up, to bleed off boost pressure. This may work for you, although you'll need to make sure the boost guage and fmu are on different vacum sources.
I think thats why they use a boost restrictor and a bleed valve to prevent a ton of boost from leaving the manifold or vaccum lines.
A check valve on the FMU signal should prevent probelms with boost gauge/FMU mix up
Fixed it for $6
you know... I'm really getting tired of building for the same project.. its time for something else!
http://www.thirdgen.org/techbb2/show...86#post1385886
squarehead
Jan 15, 2015 07:02 PM
