711rwhp 745rwtq
From: I reached back like a pimp and smacked that LS1....
Decided to strap the car down again just for the hell of it. Made-
711.7rwhp @ 5,350
745.2rwtq @ 4,800
That was at 21psi, through a full exhaust, a mix of 93 and 110, 25 degrees timing, and 10.9-1 air fuel at peak horsepower.
711.7rwhp @ 5,350
745.2rwtq @ 4,800
Re: 711rwhp 745rwtq
711.7rwhp @ 5,350
745.2rwtq @ 4,800
711.7rwhp @ 5,350
745.2rwtq @ 4,800
.Gonna take it to the track?
Rich Krause
Thanks guys
It has been to the track (numbers are in my signature)
At 18psi, 3,800lbs, on 17's it did
60ft 2.144
1/8 7.76
1/8 101
1/4 11.531
1/4 133
60ft 2.017
1/8 7.595
1/8 102
1/4 11.325
1/4 131.88
On the 11.3 run I tried shifting into 5th because it's going through the traps at 6,300 in 4th (well past peak HP).
I'm going to change the gears to 3.08's, or at least put a taller tire on it before I go to the track again.
1st and goal- The exhaust is a 3.5 single pipe from the turbo back to an SLP two on the left muffler and tailpipes. I modified the muffler to have a 3.5in inlet (the core of the muffler is 3.5 oval). There are pics of it at the website listed in my signature. It is VERY quiet and there are no cats. I may try to dyno it with an open downpipe just to see what happens.
60ft 2.144
1/8 7.76
1/8 101
1/4 11.531
1/4 133
60ft 2.017
1/8 7.595
1/8 102
1/4 11.325
1/4 131.88
It's a stock opti and coil with an MSD 6A, taylor wires, and champion plugs.
I may switch to a digital 6 so I have a 2-step.
Jordon, did you decide what you are changing your cam to?
Still not a stroker either
