Need help with crankcase pressure?
Old Jul 2, 2003 | 10:43 PM
GEES97TA's Avatar
Unhappy Need help with crankcase pressure?
I am confused i have a pcv vavle hooked up which probably dont work under boost and the tube that used to go to the thorrtle body is capped off...i have a breather were that tube used to be but i get excess crankcase presure under boost i even smoke a little what can i do did they hook up something wrong PLEASE HELPPPPPP....
Old Jul 3, 2003 | 02:32 PM
LT4ultraZ's Avatar
I hooked up the pvc and the tube that comes off the right side valve cover to the inlet before the supercharger. I had the same problem at first, it caused a oil leak.
Old Jul 3, 2003 | 04:14 PM
Camaro_SS/R's Avatar
This is kinda important to do. On top of this, I threw out the PCV vavle which was not functioning sufficiently causing my oil to shoot out from my dipstick when I hit heavy boost. I put in a bigger Moroso oil separator instead of my new PCV valve.
Doing this will give you some vacuum to help the rings seal better and because of that will make your engine produce some extra horses. Also this will reduce blowby as well.
Finally the breather will not give any vacuum but may also allow foul smell to get into your cockpit.
Some people I believe are doing just the breather and is working ok. I won't do this unless I have to.
Old Jul 3, 2003 | 09:22 PM
96TurboTA's Avatar
Now I know why my intake started leaking with less than 10miles on the new motor. the lifter valley must be pressurizing under boost via the passenger side valve cover.
Old Jul 3, 2003 | 10:04 PM
GEES97TA's Avatar
Can someone show me pictures are show me a detailed diagram on how do route the hose's and i have a powerdyne so were would it go i know you said before the blower but were? do you have to drill a hole to mount a grommetor something im confused if you can please help.Right now i have the PCV valve hooked up and the tube on the pasenger valve cover going to the TB what will happen that way...thanks again for the help
KYWes
Jun 14, 2022 06:52 AM
canuck94z28
Aug 19, 2015 05:50 PM
karpetcm
Aug 14, 2015 03:02 PM
350350
14
Aug 11, 2015 12:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
