View Full Version : Fuel and Ignition
Pages :
7]
10
- Autolite xp5245 0.060" or 0.050" gap?
- Hard starting after fuel pump install
- Stupid Question
- Does the Tornado or Airaid tb spacer add power?
- Fuel Pressure?
- Where to get injectors flow match and cleaned?
- 94Z idles but will not rev, towed home
- no fuel gauge!
- car cranks...but wont fire
- Question about Commander 950 for TPI
- Help!
- Dual in-tank with dual 3/8 lines - Almost Done
- How to install racetronix wiring harness?
- Fuel pump removal tool for a 99?
- starting problems
- icm check
- wiring harness issues
- difference between 98 and 99+ spark plugs
- Trying to remove the gas tank?!?!?!
- Going over 80% injector D.C.
- RaceTronix pNp kit thumbs up!
- ob2 says cant connect to computer mean
- racetronix FP install problems.
- Fuel pump noise
- Fuel pump relays...what do they really do??
- No spark at coil
- Will 16.2 Ohm injectors work?
- Stock Line to AN Adapter Fitting
- Coil or Ignition Module or Tachomter or Cruise Control Cable
- aftermarket Lt1 fuel rails
- Fuel Pump Bucket
- Is this opti really OEM on Ebay??
- 383ci w/cc306 and 175hp shot ... Which injector?
- 37lbs injectors with 330rwhp?
- where does this hose go??
- injector upgrade question
- Car wont start....think its the fuel pump
- Fuel filter thread size
- Fuel system thoughts....
- No power at fuse #5, PCM doesn't turn on fuel pump...fusible link?
- new pump problems
- Wiring/Testing a relay
- Injectors question???
- weld on sumps for stock tanks?
- opti is bad
- What opti are you running?
- Summit Racing Street & Strip Multi-Spark Digital CD Ignitions
- Fuel Pressure Question
- gas tank from 99 Z into 97 SS
- fuel cell ?
- Low fuel pressure
- fuel pump no good? (thinks its out of gas at 1/3)
- check valve uninstallation
- Does this look bad? Fuel level thingy...
- Fuel/starting issue
- Please Help.. opti issue i think
- 95 3.4l v6
- Quick Question about the Taylor OTVC kit
- opti to coil conversion
- Fuel pressure kept building up after going to zero.
- Braided fuel line questions
- stock pump supports how much rwph?
- Fuel Pump
- slight miss!?
- Fixing the troublesome fuel gauge
- install used fuel pump??
- fuel pump wiring
- How much power can A/f rob?
- Stock FPR and 50psi??
- Who knows about Flamethrowers?
- Plug Wire Testing
- new fuel pump problem? runs good for 5 mins and idles all day
- Is there a write up for Spark plug wire crimping?
- In line electric fuel pump issues
- Fuel filter causing lean?
- hyfire 685 / coil question
- Needs some injectors super quick, help
- 32lbs for 503?
- how to drop fuel tank?
- LTx vs LSx Fuel Pumps
- Optispark install problem
- Walbro 255 vs. 255HP
- Expected fuel press??
- Anyone have experience with this ebay opti?
- Gas leak after removing the fmu
- Will injectors off of a newer mustang/cobra work om my LT1?
- How to do an injector change
- Intermentant opti wireing problem
- Plugs for forced induction?
- 6an Fitting Question and External Pump question
- Regulator question
- stock fuel pump - how long does it last?
- Carb LT1 Guys in here please!!
- New gauge for fuel pressure. Is this normal?
- Racetronix Fuel pump harness....
- stand alone distributor?
- Both dual in-tank pumps runnig all the time.
- 6 miles to the gallon
- Fuel Pump Suggestions
- Need info on FAST rails, adapter kit, and fittings
- Fuel line question
- WHITE spark plugs
- Poll
- Here we go, another fuel system thread!
- Fuel pressure gauge
- Fuel Pressure?
- fuel cell installation
- Can I use 30lbs Injectors??
- Gas leaking from fuel rail/injectors
- Car doesn't hold fuel pressure
- Dual Walbros w/ Single stock line! Your what is your RWHP ??
- multiple issues with my 94LT1
- lets see your sumps!
- using 36lb injectors
- MSD 8252 coil
- Msd 6al
- Odd Noise near the rear
- Front, and Rear O2 sensors, whats the difference?
- SES Lean Fuel Code Help
- Who knows how to use MSD 6BTM?
- Will these AN fittings work?
- car died (3 times)
- Electrical Problem?
- Anyone know how to Test the Optical Sensor within the Optispark?
- Injector Sizing, yet another question
- Just a thought before i replace the injectors
- Fuel pump cut off switch
- Car runs without fuel pump relay!
- spirits in my tailpipe
- Fuel Pump Relay
- Major fuel problem need help?
- Fuel line question?
- Modifying fuel rails for AN fittings without welding
- Starter housing broken?
- Zay Ss
- EVAP delete questions
- Upping injectors, regulator too?
- Injector serial numbers
- Solenoid or Starter?
- Looking for fuel line upgrade pics...
- 95 Z28 code 43 Runs sluggish Help Please?
- Walbro 255 GSS341 intank fuel Pump problem
- msd on 3.4L worth it or not??
- ARGGHH!!MAP & MAF, O2 sensors AND I'VE HAD IT!
- Fuel lines
- calculating GPH fuel consumption
- Delteq and MSD DIS4 **need instructions or schematic**
- new 37lb racetronix injectors
- Bad fuel pump or sending unit?
- upgrading my ignition system
- matched injectors for an lt1
- Duty cycle for injectors?
- Injectors too big?
- injector size calculators
- LT1 Fuel Pump
- 383 Injectors - 37# too small?
- No Pressure
- Mototron 60# injectors
- Another IAC problem
- What size injectors?
- 94 lt1
- high end stumble, fuel pressure readings...
- good fuel system for le2 setup
- Fuel Pressure /voltage issue
- Time for some "Fuel and Ignition" stickies - ideas????
- Holley Fuel Injecters
- What glue for the Fuel Pump Install?
- Fuel Pump Accordian Hose Install
- Lean?
- Anyone had problems with this...
- LTCC wiring, complete please
- Legit fuel pump???
- installing fuel pump
- jetronic and uscar connecters
- What should the O2's read during WOT?
- Fuel pressure question NOT camaro specific
- Ltcc setup where to mount the box?
- What connector type with ltcc setup
- Walbro Fuel pump
- don't want to get wrong injectors
- dfi and stock gauges? need help
- Where can I get plug wire crimps?
- racetronix fuel pump-install?
- Fuel pressure problem
- Is this site Legit???
- Granatelli Fuel Pump?
- Help me design a simple, quality fuel system
- Fuel line ?
- Fuel pump for 2000 V6 Camaro???
- sparkplug Wires
- Replacing opti-spark with LS-1 Ignition
- running rich
- Shaking, backfiring, bad
- Need a Fuel pressure tester - OTC or??
- Ls1 coil and ls2 coil same connectors?
- Modifying Stock Fuel Rails for -AN Fittings
- please post your le2.2 car or equivalent ideling vacuum i am chasing a low vacuum
- Mounting a Holley Regulator (Orientation)
- very low fuel pressure
- Something is broken in msd 6al box
- Which carb should I go with?
- What size fuel injectors?
- Another which gauges thread
- Racetronix 79# injectors?
- Spark Plug Threads
- stock injectors??
- fuel pump change and best pump?
- Where to find this?
- Another Loss of Power
- what fuel pump
- Loss of power.
- fuel PSI with SVO 30's?
- Anyone tried repairing their fuel sending unit?
- ICM's keep going out
- Will 02 ls1 fuel pump work in 97 z/28?
- Anyone have any trouble getting 83# and higher injectors to idle correctly
- Racetronix Fuel Pump:Necessary to Mod the Bucket
- Overloads And Dies After Repair..... HELP
- running really rich...one light from completly rich
- Has anyone tried the new Racetronix imperdance converter
- Would a New Battery Help Performance?
- Megasquirt II
- which fuel pump to get?? i get to dicide by tonight
- Pistons 6 and 8 have spark but no fuel
- stupid question about removing...
- Those with F1 and cubes...build me a fuel system
- Need a fuel line part Number...
- My 95 F Bird Hard Start An Goes Dead Sum Tymes Smell Gas
- Walbro fuel pump problems
- Too big of an injector
- 26.8lb injectors to 28.8lb ???
- Megasquirt! Anyone use this fuel injection?
- Fuel Pump
- Caspers Electronics V-Plus Fuel Pump Voltage Boosters
- MSD DIS 4 with Delteq.. Wiring diagram
- Ignition amps?
- A1000 Pump & Filters
- is a 95 f body a obd 1 or 2
- fuel pressure regulator and cold weather starts
- Would this be a hazard?
- Fuel line rec. size
- gas problem
- Fuel lines
- msd wires
- alternator issues with wiring
- Ignition Pigtail Wire Plug-ins
- fuel pump pigtail
- Anyone have pics of dual intank fuel pumps
