Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel pressure gauge
Old Mar 18, 2008 | 08:25 PM
slicknick54's Avatar
Fuel pressure gauge
Where do you install the fitting for the fuel presssue gauge on a 97 camaro lt.
Its an autometer gauge
Old Mar 18, 2008 | 11:07 PM
The only access as stock is on the back of the fuel rail.
Old Mar 18, 2008 | 11:25 PM
My recommendation it to get a -4AN 90-deg swivel fitting (NOS #17535 or similar) to screw onto the Schrader valve (after removing the valve core). That gets the connection pointed to the side, rather than toward the cowl. Run a short -4AN braided SS hose to a location away from the engine heat and vibration, and put a -4AN to 1/8" NPT adapter on the end of the hose (or get a hose with -4AN on one end and 1/8" NPT on the other) so the fuel pressure gauge (if mechanical) or the fuel pressure sender (if electronic) can be screwed into it.
Here's the NOS fitting screwed on the Schrader valve:
http://members.aol.com/Fredrick518/Photos/bkofint.jpg
Old Mar 19, 2008 | 12:21 PM
Where can i get the screw and the rest of the parts i need ? Local automotive store or summit?
Old Mar 19, 2008 | 12:35 PM
I have called napaand autozone and they said they dont have any of that. Can someone show me where they got theirs. Thanks guys.
Old Mar 19, 2008 | 01:58 PM
NOS parts, including the swivel fitting, hoses and adapter are available from sources like JEG's and Summit. Anyone who sells NOS components will have them. And you can find equivalent parts from Aeroquip, Earl's, etc.
Old Mar 19, 2008 | 02:34 PM
http://store.summitracing.com/egnsea...115+4294906716
I found this 3AN 90 degree
Old Mar 19, 2008 | 02:36 PM
http://store.summitracing.com/partde...5&autoview=sku
Would that be the hose i need.
Old Mar 19, 2008 | 04:55 PM
The Schrader valve is size -4AN, not -3AN. You need a female fitting that will screw onto the male -4AN Schrader valve. If you don't want to use a hose, and just screw the gauge or sending unit right into the fitting on the Schrader valve, you need a swivel fitting that is -4AN female on one end (screws onto the Scrader) and 1/8" (0.125") NPT female on the other (gauge or sending unit screws into it).
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
Moshbmx1
Feb 17, 2015 10:51 AM
