Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Walbro 255 vs. 255HP
Old Mar 31, 2008 | 06:12 PM
mdacton's Avatar
Whats the difference in performance and How much power would one be good for? vs the other one
Old Apr 12, 2008 | 10:06 PM
OBE1 95Z28's Avatar
The standard 255lph pump will delivery the same volume of fuel up until about 60psi. After that point, the standard 255 pump starts to die off whereas the HP keeps going.
Old Apr 14, 2008 | 12:05 PM
I thought I answered the same question for you at least 2 weeks ago in a PM
Originally Posted by Injuneer
Originally Posted by mdacton
Is a walbro 255 big enough pump?
I get no drops in pressure and its possible my pump is a HP so it does not flow good til 80 psi.
I'm not sure, maybe add another one?
According to the WALBRO pump data, the high pressure pump flows 1 GPM more than the standard pump, all the way up to 50psi. When you go over 50psi, the high pressure pump will flow significantly more than the standard. At no point will the high pressure pump flow less than the standard pump - it always flows more. So that is not your problem.
http://www.autoperformanceengineerin...l/fpspecs.html
Old Apr 14, 2008 | 03:24 PM
mdacton's Avatar
You did, I didn't understand how much more it flowed and how it flowed more at high PSI.....but I made this post around the same time
Either way...it was the injectors I got a set of 60# and its alot better now.
Now I have new problems
Quickss96
Jan 29, 2016 05:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
mrwz28
Jul 8, 2015 09:11 PM
SpeedJunkee
Jun 6, 2015 04:27 PM
