Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel line question
Old Jan 5, 2008 | 08:05 PM
walt355's Avatar
Fuel line question
While Welding on my cage today I had a small fire and crapped the Fuel lines that run From under the car to the Rails. What other options are there for running fuel lines if any? Ud kinda like to go with a braided line. I have a ****load of 4an line laying around but would that be big enough to support 500RWHP? Just lookin for options, Thanks
Old Jan 5, 2008 | 08:13 PM
mdacton's Avatar
they sell those lines as a kit they aren't very expensive.
You could get hard tube adapters for a 5/16" tubing and 3/8" tubing and adapt the braded line.
4 an is too small......
Old Jan 6, 2008 | 09:15 AM
walt355's Avatar
Run the whole line in braided, Or adappt from the origial sp;ice under the drivers floorboard
Old Jan 6, 2008 | 09:37 AM
mdacton's Avatar
adapt under the floor
Old Jan 6, 2008 | 10:09 AM
You want to at least match the stock fuel line, which is 3/8" on the supply side, and 5/16" on the return. Use -6AN hose/fittings.
Old Jan 8, 2008 | 05:12 PM
Funkybird's Avatar
I just replaced those with the stock ones on my car. I think it was $35 for all new plastic lines.
Old Jan 13, 2008 | 02:09 AM
jshz28's Avatar
Any one ever used standard rubber fuel lines on our high pressure fuel systems, i wanted to try but had friends say no. Any one done this and how did it work
Old Jan 13, 2008 | 07:36 AM
AL SS590 M6's Avatar
Moderator
Don't try it on the feed side. Rubber hose and hose clamps aren't reliable at the 45-60 PS1 that late model fuel injected cars run. Now on the return to tank lines there sholdn't be much pressure at all.
HectorM52
Jul 30, 2017 11:46 AM
Deadbolt24
Jan 19, 2015 01:29 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
