Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel lines
Old Nov 27, 2007 | 10:05 AM
lt1loudmouth07
Guest
Posts: n/a
Fuel lines
when i was over at my friends he cut his plastic fuel lines that run in to his fuelpressure regulator. My question is can we still hook those up to the regulator with them being cut like that. he was doing the head gasket thats why. he was lazy and cut the lines. could i reconnect them and put clamps on them
Old Nov 27, 2007 | 02:42 PM
lt1loudmouth07
Guest
Posts: n/a
fuel lines
I have 45 viewed on this and no one know's
Old Nov 27, 2007 | 05:22 PM
There's only one line that goes to the FPR. The other one goes to the passenger side fuel rail. You can get a replacement set of lines for less than $20. Much safer than trying to piece them together. Check Shoebox's parts list.
http://shbox.com/1/Parts.htm
Old Nov 27, 2007 | 11:44 PM
I guess your friend likes to waste money and make extra work for himself. The tool to remove them is ~$5. The factory manual says to replace the lines if there is ever any damage.
Old Nov 28, 2007 | 07:53 AM
lt1loudmouth07
Guest
Posts: n/a
Fuel
Thank you Injuneer and Shoebox i can allways rely on you guys to respond quickly
Old Nov 28, 2007 | 10:25 AM
01Z's Avatar
01Z
I know there are plastic fuel line repair kits at the friendly NAPA store here but do not know if they have them for that particular size. The one I bought was to splice into a section after the fuel filter on another model of car. It worked perfectly but cost about $20.
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
