Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
good fuel system for le2 setup
Old Feb 3, 2008 | 10:18 PM
sn8ke eatr's Avatar
im looking to do a 355 le2 motor with about 12:1 compression. my question is what would be an adequate fuel system without blowing my budget. my car has 181 thousand miles and i know it would be wise to upgrade everything. so what would you suggest?. btw im running 32lb injectors already.
Old Feb 4, 2008 | 07:48 PM
z28_theantirice's Avatar
Racetronix fuel pump kit and make sure your FPR is in good working order and you should be set!
Old Feb 4, 2008 | 10:51 PM
sn8ke eatr's Avatar
cool thats what i was thinking, thanks
Old Feb 5, 2008 | 05:00 PM
ulakovic22's Avatar
Might want to check out your duty cycle with those injectors once you get everything all together and ironed out. Might be a tad small and depending how close it is you might want to check out larger injectors.
DirtyDaveW
Dec 1, 2016 05:37 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Jul 4, 2005 05:00 PM
