View Full Version : Fuel and Ignition
Pages :
2]
10
- 1996 Fuel Pump not powering on, troubleshooting underway...What next?
- 95 Z28 Fuel Pump Issues
- Weird issue with Fuel Injectors...
- 24lb ev1 injectors?
- Fuel Tank Swap?
- Range of AFR variation at idle?
- Fuel Pump?
- Opti Spark Problem
- Help, part needed. Ignition.
- Not getting fuel...
- Bad injector or just o ring?
- Purge canister valve help!
- wrong ignition timing?
- 1993 LT1 flashing codes 16 and 36
- 89 Iroc z map sensor
- New ICM just fried!!! Bad opti?
- Opti harness connector
- Bad opti harness connector
- What are the stock LT1 injectors? Multec / Bosch type II
- Car out of storage, won't start
- 1985 camaro
- 1995 Z28 Fuel relay
- Stock 94 z28
- New fuel injector fitment and advice
- tech issues
- aftermarket wires clicking noise?
- Bad FPR?
- VAT or what?
- Bank 1 LT Fuel Trim at 139 at idle. 128 as soon as gas is pressed
- help with codes
- Where to buy LT1 fuel injector(s)?
- 95 Z28 problems optispark maybe?
- Bad ICM?Starts when cold, runs great, dies
- Worth Keeping 58MM ProProducts Throttle Body?
- Fuel pump dead/dying?
- 94 Z28 won't crank please help
- MSD Ignition wires ?
- LTCC ignition box w/built in 2 step. Finally figured it out...
- fuel gauge
- Selling My Camaro Z28 F1
- New starter?
- weird ignition problem
- My car cut off and wont start.
- 97 z28 runs great dies mile down rd
- fuel problem need help
- Having some serious problems with shutting off.
- High RPM Hesitation
- Wireing Harness Question?
- Help with fuel system I think?????
- Starts had when hot
- Please help me
- Ignition switch or cylinder bad??
- 2001 Z28 right bank lean
- Occasionally no start/stalling, Running a little rough
- P1361 Code and Delteq
- No power to accessories with ignition turned back
- What is best LT1 fuel pump & INJ??
- Holley 512-502 regulator
- Car just shuts off!!!!!
- 83 Z28 quadrajet question
- 96 Totally dead except security light - Intermittent
- losing fuel pressure under load
- Diagnosing Ignition Issues on 93 Z28
- Fuel injector's perfomance
- Strong Fuel smell LT1
- runs dies won't start
- plz help fuel pump/sending unit
- cold motor, hard to crank!
- Fuel Tank Vent 69 Camaro
- Timing help with 350 and New MSD DIST.
- 86 Z28 350 Carb, What Fuel Pump should I get?
- Pump for 36lbs injectors?
- Quick octane question
- Simple Fuel Pump Question
- 95 z28 starts but doesnt run long. HELP!!!
- 95 Z28 fuel pump woes. 1st post here
- Injector pulse
- no power to Throttle Position Sensor from ECM
- 1991 5.0L cranks but no start
- help me please someone
- 1978 Camaro intake question
- Am I missing something??
- Oil Cooler on '94 Z-28
- Siemens Deka Injector Question....
- 97 3.8 38.7 mpg?
- Help!!!!!!!! Cranks but no start or spark
- Choke won't kick off, Elec Q Jet
- lost my keys need help getting car started
- 2000 5.7l misfires bank 2
- Differences in fuel tanks 94-97 vrs 98
- optic distributor
- 89 Camaro running rich, dies when I stop
- 97 LT1 Fuel Pump Assembly Install...
- 2 codes related or not
- car starts rough after pumping gas
- only getting 15 mpg
- 1996 lt1 starter problem
- Old fuel smell at start up
- Elec Q Jet Carb, Choke issues
- Gas gauge problem
- E85 & Nitrous???
- Fuel injector cleaning or flow matching
- engine just runs when it wants too
- hard start
- Fuel Pump Help
- Fuel Rail crossover tube O-ring Size '95 Z28
- 96 Z28 need help
- 1967 exhaust is rich rich rich
- fuel, spark, timing, comp OK but not running
- Camaro Crank but no start
- Rear plastic fuel lines part# ?
- ls1 fuel tank in lt1 car
- No power to anything.
- Security System
- Where is the fuel relay for an 2002 camaro
- ignition/security problem
- Fuel pressure regulator o-ring size
- Hard Starts not fuel pressure
- No power to my fuel pump on a 2002 camaro z28
- Seafoam in fuel tank then smoke
- No fuel pressure, need help!
- Way too much initial timing, but it likes it... why?
- Pig rich at idle/low loads
- 96 lt1 z28
- Need help picking EFI System for my 3rd Gen
- constant humming from fuel tank
- Opti install, Starter Fire HELP!
- Fuel Injector Cleaning? - Ebay seller? $17/injector
- wont start on it's own
- 97 Camaro, bad fuel pump, interchangable?
- Car runs rich after 383 instal
- Sending unit
- Fuel Pressure leaking down. Completely stumped!
- 1997 LT1 random misfire help.
- question about OTVC setup.
- Budget Fuel Pump
- Draining gas tank. Fuel pump prime connector?
- 1999 z28 5.7 ls1 coil problem
- fuel and injection
- hhhheeeeeeeeeelllllppppp no start
- fuel pump wont turn on!!
- How to wire a mallory 667s to work on a 97 lt1
- Fuel pump access door
- what have i done?
- fuel tank spitting out gas
- best spark plug
- ls1 coils not firing and fuel psi low
- Car dies off throttle .....
- LT1 Fuel Pump Troubleshooting
- best fuel pump ?
- Just double checking....
- bad plugs for lt1s
- 80lb Injectors on 92/93 LT1 - idle issues?
- fuel tank building pressure
- Camaro ss 97 problems start after change injectors !!!
- Fuel Pump
- dumb (possibly newbie) question here...
- 97 LT1 miss and flooded after standing
- No start
- fule pump
- 93 z28 won't turn over
- LT1 Running Lean, Datamaster File attached, please help!
- v6 to v8 fuelpump question
- 383 injectors
- Where can I find the Vavle Stem for Schrader Valve on fuel rail?
- walbro gss 340 installation
- A.I.R. (AIR) Driver Side Emission Tubing (1997)
- '97 Camaro 3.8 P0121, p0300
- Wierd problem with ignition (I think)
- ignition problems on a 96 camaro lt1
- New Racetronix install now will not run
- Spark plugs
- Fuel pump replacement issue...
- Excessive Tank Pressure
- Replacing Ignition Cylinder
- A.I.R. (AIR) Rebuild
- 82 crossfire no go injectors
- fuel gauge stops working sporadicly
- Post up your Racetronix pump reviews....
- Help Identifying Injectors
- How to install fuel sending unit?
- fuel pressure
- Difficult starting when HOT
- 3.8l v6 number 6 missfire.
- in need of injector help
- Starter Clicking, then starts.
- !!!!!!97 camaro running problems!!!!!!!!
- LTCC installed successfully...
- lg4 305 computer to hei non computer swap.
- Running lean
- Opti rebuild?
- 93 octane with E10 vs 91 octane?
- z28 huge problem
- 5.3 injectors in a lt1
- Plugwire Length
- OptiSpark Choice
- Power for universal coil
- Plug Wires
- Intake suggestions?
- weak fuel pump = bad gas mileage
- fuel guage
- Injector Identification / Specs 621031 - Green Ring On Top (Not Full Green Top)
- White smoke in engine
- GM stock fuel pump defective in 95 LT1
- what is normal fuel pressure?
- 94 Z28 Fuel smel - Is the EVAP system "closed"?
- Are these injectors fine??
- Fuel pump/relay schematic
- Fuel Injector Swap
- 94z fuel pressure regulator leak
- Misfires, Need Help
- 94 Z28 dies on Idle need help!
- Fuel Smell
- How can I drain my fuel tank?
- need new carburator
- Can you test a opti
- Need help: how is your fuel tank o-ring/lock ring configuration?
- Fuel line coating options
- Fuel system issues
- fuel pump trap door for v6 and v8
- Optispark adapter question
- Walbro 255 plug-n-play
- 1994 Z28 Smells like fuel
- Fuel pressure bleeding problem
- distributor/optispark problems
- Trap Door Mod - Don't want to Blowup The Car!
- HELP 89 z28 with carb engine
- Who makes the best injectors?
- Strong gas smell(gasoline, not flatulance)
- Fuel pump/electrical problem HELP!!!
- Racetronix Fuel Pump parts
- wont start or turn over.. Need help
- Fuel pump help
- LTCC ignition question
- Can someone please help?!?! URGENT
- Z28+water puddle=bad!!
- NGK's or ACDelco's Spark Plugs?
- Need Help, 94 Camaro Parts onto 96 Trans Am
- Magnacor wire Yes or no
- Help, no start
- Replaced Fuel sender assembly 96 LT1
- Starter and Fuel Pump?
- 96 Z28 LT1 - hose running off the fuel pump doesnt attach?
- which octane do you use?
- LT1 Sputters when holding RPM, throwing DTC34
- Header melted a hole in plastic fuel line
- v6 fuel pump died
- I need help fuel pump issues
- 1050 dominator leaking center squirter at idle
- Does anyone know the exact length of the feed and return plastic fuel lines ????????
