Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
95 Z28 code 43 Runs sluggish Help Please?
Old Feb 17, 2008 | 10:56 PM
buzzkill's Avatar
Hello, I'm new to this site due to being the proud owner of a 1995 Z28 camaro that has been misstreated but i plan to bring her back to life. The car when i purchased it had a bad miss and ran horrible with just spirts of power every now and then. After searching i notices the plug wires were routed poorly and some were burnt and taped up due to the pacesetter headers that were installed on the car. I purchased plugs, wires, oil ect.. After new plugs/wires were installed, it ran 90% better with no dead miss. The car runs very sluggish with low power on take offs but picks up a little power at upper rpms but it kinda backfires or pops when it starts to wind down. At the local parts store we ran the scanner and it pulled up a code 43 Electonic spark control module. I have tested the knock sensor and it tested at 4.8 v and when i tested the ohms read between the 3.3 to 4.5 range. The carlot i got it from changed out the PCM computer. It has been replaced with a used one that was written on with a marker 94-95 camaro/firebird 5.7 and As-Is. I pulled out the wiring harness going to he knock sensor to check wiring back to the pcm and the blue wire was ok but there was a black wire that was just cut off and im not sure where it goes to. Im trying to get this car back to perfect running condition, please tell me where to check or what to do before i need to go buy a distributor or another computer. Thank you for your time.
Old Feb 18, 2008 | 12:35 PM
Please post only on one forum. Do not put duplicate posts on multiple forums.
cmdeshon
Jan 4, 2015 11:15 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Dec 1, 2014 08:08 AM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
