Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Hard starting after fuel pump install
Old May 19, 2008 | 07:54 PM
jeffcamaro2007's Avatar
I just finished installing my racetronix fuel system last week and it is usually much harder to start than before. sometimes it will fire up immediately but most of the time it takes atleast 3 seconds or more. once started it runs perfect.
Old May 19, 2008 | 11:46 PM
6SpdLT1Z's Avatar
Firstly I'd like to mention that I suggested you replace your fuel pump with an OEM one.
I don't have any experience with racetronix fuel systems, but what kinda amperage does the pump require?
Old May 20, 2008 | 09:07 PM
OBE1 95Z28's Avatar
Check your fuel pressure at the Schrader valve after priming; if the fuel pressure drops off rapidly there may be dirt in the check valve of the fuel pump causing hard starting.
Old May 20, 2008 | 09:14 PM
97 RedSS's Avatar
Did the pump fit inside the bucket without any issues? did you glue the top back on?
Your losing pressure somewhere..
Old May 20, 2008 | 11:05 PM
98 does not have a bucket.
Old May 21, 2008 | 10:15 AM
2000GTP's Avatar
That is what I was thinking. That is why Racetronix recommends cleaning the tank very thoroughly before installing the pump. When you did the pump, did you drop the tank or did you do the trap door method?
Old May 21, 2008 | 07:33 PM
i dropped the tank. I did not clean the tank out at all.
Old May 26, 2008 | 10:07 AM
starts alot better now once you prime it first.
Gtpguy
Jan 26, 2015 04:50 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
