Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
95 3.4l v6
Old Apr 13, 2008 | 10:37 PM
RingsideFitness's Avatar
95 3.4l v6
Hey guys just found this website and glad I did.
I just bought a 95 convertible that has been sitting for 1 1/2-2yrs and having an issue.
The car will turn over good and strong, it just will not start. I cannot hear fuel pump or relay. Also the fuel gauge doesnt work.
Any help appreciated.
Thanks,
Shane
Old Apr 14, 2008 | 01:16 AM
GreasyB's Avatar
Try jumping over the relay to see if the fuel pump will kick on or not. If it does not then you know that the problem is most likly not in the controll circuit.
Old Apr 14, 2008 | 06:34 AM
How do i jump over the relay?
Old Apr 14, 2008 | 07:02 AM
The easier way to see if the pump will actually run is to jump 12v to the fuel pump prime connector. If it runs, then you can worry about messing with the relay.
Since the gauge also does not work, it sounds like maybe someone was working with the pump assy and had some trouble. Here is some other info that might help further.
Old Apr 14, 2008 | 07:54 AM
Will i hear the pump run once i jump the prime connector if the pump is good? also the key needs to be in the on position?
Old Apr 14, 2008 | 08:21 AM
2000GTP's Avatar
Just jump the connector, the key doesn't have to be in the run position. The pump should energize then.
Old Apr 14, 2008 | 03:31 PM
what's the best way to jump it?
Old Apr 14, 2008 | 03:59 PM
The politically correct answer is "use a fused jumper" (a piece of wire with an inline fuse). Attach a wire from the red + terminal on the RH shock tower to the prime connector (obviously, do not let the end of that 12v jumper touch any ground). An attached fuel pressure test gauge will tell you if it is working properly.
Old Apr 15, 2008 | 07:52 AM
Alright guys, tested pump with jumper and no response that i could hear.
What next?
Thanks,
Shane
Old Apr 16, 2008 | 07:10 AM
Check at the last connector under the car to see if power is actually getting to the pump when you jump it. The last link in post #4 shows where it is and what wires are what. If power and ground are good there, your pump is likely dead.
Naanz
V6 Tech
Feb 14, 2016 11:11 AM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
94-3.4
V6 Tech
Oct 13, 2002 06:37 PM
iconrl
V6 Tech
Oct 1, 2002 09:30 PM
Scotty2Nawty
V6 Tech
Sep 19, 2002 12:27 PM
