Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
gas problem
Old Nov 27, 2007 | 04:10 PM
biggie01's Avatar
gas problem
my 2000 z28 is dead. it just shut off one night,it seems like it ran out of gas but it has gas in it. i change the fuel pump but its still not getting any gas up front.the pump is not making the noise but its still sending gas in into the lines.(i think the pump is working its does it matter about the noise) i also change the filter still no luck.i look for the relay 4 the pump but could not find it. confuse can any 1 help.
Old Nov 27, 2007 | 06:59 PM
Bluovlh8er's Avatar
you need a new relay.
my car(s) shut off and i wiggled the relay and it fires back up. i have 2 camaro's...... i wash my motor all the time and dont cover anything so water gets in the relays sometimes lol. the relay is in the fuse box in the driver side front, right behind the headlight...
Old Nov 28, 2007 | 03:15 PM
biggie01's Avatar
change the relay. still no luck,can any tell me should the pump make the prime noise. i'm about 2 change the plug that goes 2 the pump and see what happen. any other suggestion? by the way the pump is made by retect is that a ok pump?
Old Nov 28, 2007 | 09:31 PM
mrmint69's Avatar
I can hear mine running in the tank so i assume your is the same way. Have someone turn the key to the on position and have someone else listen down by the tank. When i replaced the pump with a aftermarket one it made a noise but it sounded completely different and was a lot quieter. How much fuel pressure are you getting at the schrader valve? It might take a lot of key cycles to get the fuel to the injectors if the fuel line was dry. There is also the possibiltiy your gauge is broke and you really are out if fuel.
Old Nov 29, 2007 | 10:48 PM
biggie01's Avatar
I just checked the pump it is working. I have a question the about letters on the pump the r stands 4 return I guess, if so the gas is not going 2 the front so were is it coming back from.
Old Nov 30, 2007 | 02:45 PM
mrmint69's Avatar
I don't understand you question. Please try again so i can follow you. Thanks
Old Dec 1, 2007 | 09:14 AM
biggie01's Avatar
I just finish messing with the car. my line with the letter r that's on the pump has gas coming back through the it where it connect. it seems like the line is block or something is not working I don't no if the regulator is bad. does anyone have the diagram the fuel system from tank to the front for 2000 z28.
Old Dec 1, 2007 | 09:23 AM
biggie01's Avatar
Old Dec 1, 2007 | 10:39 AM
The fuel system in the F-Body LS1's is a "dead end" system, with only a single line running forward to the engine/fuell rails. There is no return line from the engine. The bypass style pressure regulator will either be in the tank, or in the filter. Take a look at the fuel filter and see if there is a return line.
Maybe someone with an LS1 could verify the pressure regulator location.
warmeck
Mar 22, 2015 06:43 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
DetroitZ28
Feb 13, 2015 07:33 AM
blac94Z
Nov 24, 2014 07:12 PM
simple
Aug 11, 2002 11:56 AM
