Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Gas leak after removing the fmu
Old Mar 30, 2008 | 03:18 PM
mrmint69's Avatar
I removed the fmu and put the fuel lines back to stock. The connection is now leaking that goes from the return line back to the tank right by the fpr. Is there a gasket or washer that is causing my leak or what could it be?
Old Apr 12, 2008 | 06:45 PM
mrmint69's Avatar
Over 60 people read it with no answers. I finally pulled it and found the O ring was bad. The part was .41 cents and took 2 minutes to replace. There is one in the female side of the return line. I bought it at the hardware store so i hope any rubber O ring will work with the fuel.
Old Apr 15, 2008 | 12:16 PM
Kevin Blown 95 TA's Avatar
I would have said the O ring, but I just read this, LOL. I don't know if those are a nitrile rubber or Viton, but good luck with it. I know some of the NAPA stores and some others carry an assortment of FI small parts in case your's dissolves.
Iamherefornow
Jan 26, 2015 04:57 PM
pologreen97z
Dec 2, 2014 10:42 AM
blac94Z
Nov 28, 2014 01:53 PM
blac94Z
Nov 24, 2014 07:12 PM
simple
Aug 11, 2002 11:56 AM
