Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Will 16.2 Ohm injectors work?
Old Apr 30, 2008 | 04:53 PM
rusnrno's Avatar
I had two stuck injectors after a cam swap and I bought these http://store.summitracing.com/partde...5&autoview=sku
injectors at Summit. I installed them and started the engine. It threw DTC 0200. I didn't think the 2.2 Ohm impedance difference would be a problem.
Old Apr 30, 2008 | 04:57 PM
Stock injectors are 12 ohm.
Old Apr 30, 2008 | 05:05 PM
rusnrno's Avatar
I stand corrected.
By the way Shoebox, I want to thank you for your tech page. I can't tell you how many times I referred to your site while working on my car. The pictures and drawings made sense out of what otherwise would have been a meaningless mess of wires and hoses.
THANK YOU!
Old Apr 30, 2008 | 05:31 PM
The main thing you have to be concerned about is that they are "high impedance" injectors, which they are. The normal range for high impedance injectors is 11-16 ohms, but there should not be any harm in using a 16.2 ohm injector. It just means the current draw through the injector driver in the PCM will be lower, which isn't going to hurt the driver. If the injector manufacturer chose to wind them at 16.2 ohms resistans, he must have determined that it would put sufficient energy into the coil to open the injector reliably.
Old Apr 30, 2008 | 05:50 PM
rusnrno's Avatar
Any ideas why it threw the DTC?
Old May 1, 2008 | 09:46 AM
The code sets if the voltage on the injector circuit drops close to "0". The resistance of the injector wouldn't cause that problem. A near-0 voltage would result from a short in the circuit, not high resistance.
nophix
Nov 30, 2014 10:26 PM
siguy
Nov 27, 2014 10:07 AM
ChameleonGreen
Sep 2, 2002 05:15 AM
Omega9
Aug 2, 2002 12:33 AM
